586,102 active members*
2,648 visitors online*
    Jun 2012
    19
    Aluminum 7075 surface finishing.
    I have some parts that I am facing off in a cnc machine. Its the top of some 1/2" places that are about 6" x 1". These are cosmetic pieces and I have them anodized type III hard coat black for the customer. I have to tumble the parts for a very long time before sending it to anodizing and there are still some swirls you can see behind the anodizing. Is there like a wire cup brush that I can use to chuck in a holder and run it across the top to smooth out the finish?
    I was looking at buying some brass wire cup 2" brushes but didnt know if they would be to rough on the surface. I know they make brushes in nylon, stainless steel, brass, aluminum, etc. I can take a scotchbrite and scuff it for about 2 mins and almost get them out. What is the best to use on aluminum for a smooth finish?
    Mar 2014
    Re: Aluminum 7075 surface finishing.
    Use 128 grit bead blast media.
    Sent from my SM-N900T using Tapatalk
  1. best price on 7075 aluminum
    By redridertwo in forum MetalWork Discussion
    Last Post: 01-22-2013, 01:02 AM
  2. Replies: 4
    Last Post: 08-26-2012, 02:57 PM
  3. 1.375-12-UNF-3B tap through 7075 aluminum with thin wall
    By charlieb3cnc in forum MetalWork Discussion
    Last Post: 02-09-2011, 08:14 PM
  4. Perfrormance in 7075 T-6 aluminum
    By DragnsBane in forum Tormach Personal CNC Mill
    Last Post: 02-22-2008, 09:59 AM
  5. 7075 Aluminum
    By mtechserv in forum Moldmaking
    Last Post: 03-28-2005, 05:27 AM
