603,872 active members*
5,051 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > wiring check please. parallel wiring to maximum current to servo motors
    Jul 2014
    39
    hi
    I`m hoping someone can check my wiring. I have a Antek 70 dc power supply that I wired
    in parallel to maximum current to my servo motors. I used red for + and – for black. I haven`t
    tested my wiring … I`m hoping for verification before I power up the supply. This supply has
    dual outputs at 10 amps each.
    Attachment 252860Click image for larger version.
Name:	10-11-2014 12-39-57 PM.jpg
    Mar 2007
    2083
    Re: wiring check please. parallel wiring to maximum current to servo motors
    thats how I'd connect the outputs in parallel
    Jul 2014
    39
    Thanks for the info. Just powered up the new wiring and everything looks good.
    24260
    If you have four motors or even three, you can also split the supplies between each pair, instead of paralleling.
    Al..
    Albert E.
  1. Please Check my wiring.....
    By racedirector in forum DIY CNC Router Table Machines
    Last Post: 04-06-2012, 01:39 AM
  2. Wiring check wanted
    By zappafan1 in forum Gecko Drives
    Last Post: 02-02-2012, 12:55 AM
  3. Help needed to check my wiring before power up.
    By gavztheouch in forum Servo Motors / Drives
    Last Post: 05-18-2009, 04:52 PM
  4. wiring motors ,parallel,uipolar adv/ disadv...
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 04-18-2009, 03:21 AM
  5. Speed Controller Wiring - check me
    By TravisR100 in forum CNC Machine Related Electronics
    Last Post: 04-07-2009, 02:12 AM
