586,114 active members*
3,310 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Need some tool lists of whats in your tool box, and what you cant live without
    Sep 2014
    22
    started working on our CNC machines at work. because the maintenance man left to live closer to family after working there 25 years.
    im only 23, and went to school for automotive service technology, Welding, and Machine tool technology
    i just love fixing things... after diagnosing failed servo drives, replacing bearings, cables, motors, servos ETC...
    i have a feeling my boss has confidence in me now, and i think they will continue having me do repairs.
    So,.... id like to know whats some of your favorite tools? if you have to go out in the field whats a list of tools that you couldn't go without?
    would like to get some detailed lists guys,
    Thanks ahead of time.
    24221
    Re: Need some tool lists of whats in your tool box, and what you cant live without
    Obvious, top of the list is a decent VOM meter, a typical electricians tool kit with fuse puller, Channel locks, Hand crimper for terminations, Allen Keys metric and Imperial, a 'scope is an asset, a lap top with a serial port, if your doing the mechanical also, then a bearing puller and if it will run to it, a hyd bearing press.
    Micrometer/dial gauge.
    A few for now.
    Al.
    Albert E.
    Sep 2014
    22
    A few for now.
    Al.
    have all above, except the "scope" you mean like a labscope?
    i was thinking about getting a borescope, or a fiber inspection cameras. cause i have been in many situations so far that i couldnt quiet see something. and had to pull covers and parts to get to. only to realize that wasnt the problem. something like this. http://www.jccayer.com/productphoto2.../2310-21_2.jpg
    24221
    Just a run-of-the-mill Oscilloscope.
    Al.
    Albert E.
  1. help..whats the ultimate roughing tool
    By acannell in forum Uncategorised MetalWorking Machines
    Last Post: 02-12-2014, 02:36 AM
  2. Tool table lists 200 tool #'s. How do I assign these?
    By Manny Machado in forum Haas Mills
    Last Post: 10-20-2013, 02:44 AM
  3. Haas live tool rpm
    By patrickpsss in forum Haas Lathes
    Last Post: 07-28-2010, 01:33 PM
  4. live tool y offset??
    By Jsheldon in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-20-2009, 02:30 PM
  5. Live tool drilling?
    By Vern Smith in forum Haas Lathes
    Last Post: 08-22-2009, 10:47 PM
