588,471 active members*
5,057 visitors online*
    Oct 2014
    Huanyang 2.2kW VFD.
    I have an Haunyang VFD driving a 2.2kW motor on a lathe, which is working perfectly. I have just added a remote panel to it which works but only when I hold the start button in, as soon as I let go of it the motor stops.
    Have gone through the manual but cannot find out how to correct it such that it latches in when the start button is pressed.
    Any advice please?
    One thing I have not done is to connect an RST core back to the VFD, could this be the problem?
    Thanks.
    atc40.
    Oct 2014
    Re: Huanyang 2.2kW VFD.
    Sorted.
    RST core connected and now working okay.
  1. Help with Huanyang HY02D223B
    By stevespo in forum Spindles / VFD
    Last Post: 02-01-2014, 09:42 AM
  2. huanyang vfd and mach3
    By Elektryk in forum Phase Converters
    Last Post: 07-29-2013, 05:14 AM
  3. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  4. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
  5. Huanyang Vfd e-stop help
    By Pplug in forum Phase Converters
    Last Post: 05-10-2012, 06:57 PM
