603,350 active members*
3,282 visitors online*
    Feb 2007
    711
    Alan's DIY CNC Mill
    I have a 30mm steel table top about 55" x 38", that is never used for anything, so I started playing around with a mill design that is built of steel plate.
    I don't really have any hard specs on how big or heavy I want it, but I am designing it large, and will scale it down to be reasonable, and to fit in the stock I have.
    The steel was essentially free, so that is the only reason this project may be possible for me. I would hope the entire project would come in less than $5k, we'll see how that goes.
    Waterjet cutting will probably be the biggest cost, besides motors and electronics. I designed in hiwin rails and blocks, but will be on the lookout for alternatives.
    I'm sure the design will change a lot before I am finished.
    I'm not sure on what kind of spindle to pick, I've been looking at the tormach spindle head.
    Right now the travel is around 23" x 8" x 11.5" and estimated to weigh atleast 600lbs for the plates. The table is 8" x 34"
    I already have a router built, and a lathe in progress, so this probably won't get started for a long time.
    Let me know what you all think!
    Attachment 253570 Attachment 253568
    Attachment 253572 Attachment 253574
    Oct 2005
    375
    Re: Alan's DIY CNC Mill
    The design is torsional wise very weak, the crossection of the y and z axis are u-shaped.
    The u-shape is not good for any construction that`s loaded with torsional forces.
    Make a back and bottom plate for the z and y axis crossection and you are fine, with this plates you make a box crossection.
    Jan 2008
    1556
    RHS would be much stiffer
  1. Alan's DIY CNC Lathe
    By alan_3301 in forum Vertical Mill, Lathe Project Log
    Last Post: 04-23-2015, 12:57 AM
  2. Alan Zavacky Community.......!!!
    By alzavacky in forum Want To Buy...Need help!
    Last Post: 06-16-2012, 12:05 PM
  3. Alan Bradley plc
    By phil spanner in forum Controller & Computer Solutions
    Last Post: 11-08-2008, 05:54 PM
