586,633 active members*
2,966 visitors online*
    Jul 2008
    267
    Sleeves on FK15 support
    I am using FK15 support for my RF45 conversion. While assembling the Z axis, I notice that the sleeve on the FK15 support is not long enough - the nut on the ball screw interferes with the oil seal.
    I tried swapping the sleeves around - no luck. Searched for others with the same problem - could not find anything.
    Any suggestions?
    I have attached a picture of the bearings I purchased.
    Nov 2012
    220
    Re: Sleeves on FK15 support
    I would email Chai and get him to send you the right size sleeves or you could make your own; they are simple. If you email Chai, take a picture so he can see what you are talking about. The picture you posted does not show the problem or the sleeve.
    Jan 2008
    1534
    Common problem. The seals may not be pressed in far enough.
    I ended up removing the seals in my blocks. I found that the seals gave the illusion of minimal play because they were touching the bearings, and in fact there was 0.1-0.2mm play between the bearings contributing to backlash.
  1. Shrink sleeves in with nitrogen
    By clayman in forum MetalWork Discussion
    Last Post: 06-24-2013, 03:29 AM
  2. Need brass, aluminum, bronze, or ??? helical threaded sleeves
    By SQLGuy in forum North America RFQ's
    Last Post: 03-12-2013, 03:20 PM
  3. Spindle Sleeves
    By sk_2002 in forum Okuma
    Last Post: 05-09-2010, 09:47 PM
  4. Anyone shrinking sleeves with Dry-ice?
    By laka in forum MetalWork Discussion
    Last Post: 06-20-2009, 08:24 PM
  5. Boring for sleeves on 3axis vmc?
    By msomerville in forum I.C. Engines
    Last Post: 08-09-2007, 11:19 PM
