I have done it many, many years ago shrinking liners into cylinders heads for valve stems. As I recall my interference was something like 0.0005 on 0.5000" diameter.
Your 0.004 interference on 3.500 diameter may not be possible because liquid nitrogen is only about -196 degrees. Have you done a calculation for the shrinkage you will get with a 200 degree temperature change.
Anyway, whatever interference you use will be very close to the reduction in your ID if the end block is signficantly thicker than your sleeve.
