586,106 active members*
3,177 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Puma TT1800SY - APC "Alarm" on start up
Results 1 to 7 of 7
    Nov 2014
    Having problems figuring out what the yellow flashing APC alarm is. We have checked the battery and that does not seem to be the issue. Does anyone else know what may be happening here? Machine will not run, and we keep getting a lubricant pump alarm 2161, but that seems to be functional too.
    Apr 2008
    1577
    Re: Doosan Puma TT1800SY - APC "Alarm" on start up
    Welcome to the forum!
    Try the Doosan subforum: http://www.cnczone.com/forums/daewoo-doosan/
    You'll have better luck there
    Feb 2013
    788
    Apc alarm is related to the Absolute Pulse Coder and depending on the code number, is either the battery...or the need to reset the home position. What is the code?
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Quote Originally Posted by Saranac View Post
    Hi
    you need to replace the new battery APC, then reset the home position by produce operation manual book inside
    Jun 2015
    11
    Hello,
    I have changed the battery and also set the machine to it reference point , but when ever i turned the machine off and put it on next day the machine shows me same alarm , i have changed the battery two times after this alarm but the issue is not solved please help me
    Jun 2015
    11
    Hello Dear ,
    Feb 2013
    788
    If you pull the battery and read the resistance of the pins remaining on the controller. If the resistance is very low, remove the cables (one at a time) and check the resistance again. If removing a cable drastically increases the resistance then one of the cables or its moror/encoder has issues.
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Doosan Z290SMY - " Two Turret Processing "
    By Heavy_Metal in forum Daewoo/Doosan
    Last Post: 02-28-2014, 06:00 PM
  3. Replies: 3
    Last Post: 12-11-2013, 04:01 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. TT1800SY move "B" after M310
    By Don18P in forum Daewoo/Doosan
    Last Post: 01-04-2013, 06:53 PM
