603,378 active members*
3,140 visitors online*
    Mar 2006
    96
    Hemisphere program
    How do you program milling a dome. Is there a canned cycle, like a pocket clearing cycle, that I could add a z feed to? Maybe a helix cycle with a slow z feed?
    Jul 2003
    1220
    Is this a full or just part of a hemisphere you want to machine.
    I have a program that will generate a helix around the outside of a hemisphere.
    Advise diameter and were you wish to start and finish. Also the dimensions of the cutter you intend to use.
    Jul 2003
    1766
    there isn't a cycle that I know of.
    I have done it in turbocnc and Emc2 using loops.
    Here is how I did this in Emc2
    http://www.electronicsam.com/images/woodcube.jpg
    http://www.electronicsam.com/images/...axisubuntu.png
    #1=1.25 (size of box)
    #2=.0625 (cutter radius)
    #3=.125 (size of box bars)
    #4=5 (degrees of resolusion)
    #5=#4 (COUNTER)
    #6=[[#1/2]+#2] (ACTUAL RADIUS OF CIRCLE - CUTTER RADIUS + RADIUS)
    G01X0Y0F10
    o140 do
    #8 = [[SIN[#5]*#6]*SIN[45]] ( X AND Y POSISION)
    #9 = [0-[[1-COS[#5]]*#6]] (Z HIGHT)
    G1X[#8]Y[#8]F3
    Z[#9]
    G18 G02 X[0-#8]Z[#9]I[0-#8]K[0-[#9+[#6]]]F5
    G19 G03 Y[0-#8]Z[#9]J[0-#8]K[0-[#9+[#6]]]
    G18 G03 X[#8]Z[#9]I[#8]K[0-[#9+[#6]]]
    G19 G02 Y[#8]Z[#9]J[#8]K[0-[#9+[#6]]]
    #5=[#5+#4]
    o140 while [#8 LT [#1/2-#2-#3]]
    G1Z1
    X0Y0
    M30
    there are some other examples and info here
    http://wiki.linuxcnc.org/cgi-bin/emc...cinfo.pl?Oword
