586,096 active members*
3,727 visitors online*
    Nov 2008
    228
    Baltic Birtch Number Of Passes
    Can Anybody here with a 40W machine let me know how many passes you need to cut through 1/8" & 1/4" baltic birtch? I do not care about burning as long as the edges are strait and only need a slight sanding. Everything I make will be primed and painted.
    Nov 2008
    382
    Re: Baltic Birtch Number Of Passes
    I use a converted 40W with the DSP AWC 608 and cut 1/8 birch with 10mm/s 15mA, and 1/4 birch with 6mm/s with 15mA.
    greetings
    waltfl
    Nov 2008
    228
    Thanks for the reply. Any quality issues with the sides? Whats the thickest you can cut?
    Nov 2008
    382
    no side issues except the light brown coloring.
    I can cut birch ply up to 3/8 inch (10MM) with reduced speed down to 3 to 4mm/s
    greetings
    walt
  1. Replies: 3
    Last Post: 10-20-2014, 02:21 PM
  2. G76 Number of Passes
    By eliot15 in forum G-Code Programing
    Last Post: 04-09-2011, 12:51 AM
  3. baltic birch questions about chipping
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 04-15-2009, 11:31 PM
  4. Roughing Passes Exceeding Finishing Passes
    By phoodieman in forum Mastercam
    Last Post: 03-01-2009, 01:21 PM
