603,308 active members*
3,264 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > FineLine Automation > previously accurate homebuilt kit machine won't cut perfect circles any more
Results 1 to 6 of 6
    Mar 2010
    170
    Check it out, my fineline automation FLA-200 (2x4) machine used to cut perfect circles, but suddenly it does this:
    Is that the product of backlash? How would I determine the exact source of the problem?
    Thanks!
    Mar 2010
    170
    Re: previously accurate homebuilt kit machine won't cut perfect circles any more
    According to Ahren of cncrouterparts.com, if I'm using the original one piece acme nuts, that could be the problem. I replaced the original acme nut on the z axis a while back, so I'm going to do that with the one that moves the z along the gantry. That'll be fun, taking off the z, replacing the part and then putting it back together. Hopefully that will fix it.
    Mar 2010
    170
    And that wasn't it. I installed the dumpster acme nut and it's still doing the exact same thing. I don't believe it's the G-code as it looks fine in Mach3, so it has to be the hardware, right?
    I've uploaded the g-code and aspire file here: http://www.mattclara.com/misc/aspire...te-channel.zip in case anyone wants to take a look anyway.
    35494
    Looks like backlash. Check for loose couplers.
    May 2012
    124
    Fun problems i discovered with my FLA100 and how i handle them:
    The 2 allen screws that hold the X acme nut to the gantry, first off, isnt perfectly level. I had to shim the hell out of mine to get it close.
    Second, those 2 hex nuts come loose. id shim it and tighten down and maybe even add some LocTite.
    Also those goofy bearing blocks on the x and y, but especially the x, come loose VERY easily. Or i should say out of alignment.
    I added a bit of loctite after disconnecting the whole YZ gantry from the X bearing blocks. Packed 2x4s under the machine to hold it up. Used C clamps to hold the bearing blocks tight against the machine, but, not TOO tight. Just enough so that all 6 bearings were making contact. Adjusted my set screws carefully, but quickly as i had loctite in.
    So far its improved a bunch. I havent had to redo the bearing blocks once.
    BUT! Junk does get into those x bearings. Even with my dust collector. Im constantly making sure nothing gets in those blocks. I recently tried to cut some alu on it and i notice that stuff is stuck on the surface of the bearings good. Probably going to have to pull all the bearings off and give them a good cleaning.
    Lastly. I had a circle/arc issue with my first board, the HobbyCNC board. Man when i went to a Gecko i couldnt believe the improvement. It was like a totally different machine.
    Now on top of all this, whats your PSU?
    I have one of the 36V switching supplies. I can hear it when its first started and i do a jog, that the current will spike/drop, and this is after its ramped up to velocity. Temperature affects this thing bad. I'm looking to put together a good torroid PSU. Just need to find the caps.
    Now, after actually looking at the 2x4 and seeing its a dual x motor design:
    I hadve buddy who had issues because his limit switches werent 100% aligned on the x. he has a rack and pinion design. Spent an evening measuring backlash/difference and shimming each side of the X. Any latency issues in your I/O will contribute to this as well.
    Mar 2010
    170
    Looks like I never completed this thread. It was one set screw on one of the rack and pinion parts had come loose and there was some slack in it as a result. When it changed directions it was a split second before the pinion started spinning due to the slack. I took the set screw out, added a drop of locktite CA and screwed it back in and haven't had a problem with it since.
  1. Making accurate circles? What do i need to fix? what to expect?
    By Rich05 in forum Charter Oak Automation Support Forum
    Last Post: 07-27-2012, 03:56 PM
  2. K40 worked perfect, now has problems with circles
    By elmettaro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-13-2012, 04:43 PM
  3. My homebuilt machine
    By jbailey19 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-19-2010, 07:21 PM
  4. Perfect shaped circles needed - Please help
    By organetic in forum DIY CNC Router Table Machines
    Last Post: 05-03-2007, 01:32 PM
  5. Homebuilt machine accuracy
    By atomgonuclear in forum Community Club House
    Last Post: 02-13-2006, 03:57 PM
