586,104 active members*
3,292 visitors online*
    Spindel problem - alarm
    Hello all, I read a forum long enough but now I decided to write the first post. My machine is a Mori Seiki SL-3B With Fanuc 5 . I have following problem .If the spindle is at any higher speed and I turn the knob is quickly reduce the speed, the circuit shuts down and I get the alarm. When pressed a NOR or REV to start the spindle, the circuit shuts down and I get the alarm. It is interesting that sometimes spindle start normally and there is no problem with speed control (not the circuit shuts down and I get the alarm). Alarms Appearing "over current field loss" and sometimes "Error excess phase sequences". The problem is only in reducing of rotation or off the spindle. With increasing of rotation of the problem is not there. Please help me what is the cause. Sorry for my English.
    Attachment 260328 Attachment 260330 Attachment 260332 Attachment 260334 Attachment 260336 Click image for larger version.
    Re: Spindel problem - alarm
    Quote Originally Posted by blasterpl View Post
    It is a pretty common problem. Normally the problem is in a few of the hybrid ics. I can not remember which ones exactly at this time. You will need an oscilloscope to find out.
    Where are you located?
    My problem managed to solve partially. Do not connect the contact 13-14, the contactor MS 2. After cleaning is better. But sometimes still lights up SPINDEL ALARM.
    Attachment 262244
    Unfortunately, the problem returned. How to check who hybrid ics. damaged?
  1. Fres spindel
    By nitrov in forum Norwegian
    Last Post: 10-04-2014, 09:46 PM
  2. Arrow2 750 Coolant problem thru spindel
    By kama in forum Cincinnati CNC
    Last Post: 03-16-2011, 01:39 PM
  3. mazak spindel alarm f46c
    By jaimeeduardo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-10-2008, 01:45 AM
  4. Haas spindel Deriver, Regen problem
    By tayfunk in forum Haas Mills
    Last Post: 09-01-2008, 03:08 PM
  5. Quicker 2 spindel
    By satneo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-18-2007, 01:05 AM
