588,531 active members*
8,621 visitors online*
    Jul 2005
    What is 4th or 5th axis bearing type ?
    I was wondering what type of bearing is used in the 4th or 5th axis.
    The axis I mean is the one which rotates parallel to the X-Y plane or which makes the rotation possible on the same axis as the normal mill
    Best regards,
    Geoff
    Jun 2003
    453
    Most likely a tapered roller bearing.
    Mar 2006
    2712
    bigg You might try crossed roller bearings from THK or IKO. These are similar to linear crossed roller way blocks but are made with circular inner & outer races. They can be sealed or open.
    DZASTR
