588,686 active members*
6,315 visitors online*
    Aug 2012
    113
    Spindle Brake or Braking Resitior on BOSS?
    What's a better setup? Installing a braking resistor to a Hitachi WJ200 series drives to stop the spindle quickly or would letting the spindle brake stop the spindle after say a half second of shutdown?
    How did Bridgeport set it up initially? I've never seen it run before my retrofit and I know it had an auto setting I'm just not sure that going from 4000 RPM to 0 RPM quickly is good for the spindle brake or even the motor for that matter. It's a Bridgeport Boss 5 with a rigid ram.
    Apr 2005
    175
    Re: Spindle Brake or Braking Resitior on BOSS?
    Original control for the brake was very simple. When either the MF OR MR relay was activated (forward and reverse relays) the small contacts on the top of the relay , would change state from normally open to normally closed or visa versa. These contacts would then be connected to the brake solenoid to deactivate solenoid when the spindle is turned off. The brake is applied when the solenoid is not active as this allows the spindle to be locked for tool changes. These small contacts are used for the flood / mist control to shut off when spindle turns off.
    As an original system, the brake is able to stop the spindle from turning very quickly as long as air pressure is above 80psi.
    Aug 2004
    51
    If you use a mechanical brake with your VFD, and you don't have a breaking resistor, you will trip out on OL. You may trip it out just changing speeds fast if your using the mechanical belt speed adjuster.
    Oct 2006
    222
    use both
    on my BP I use a brake resistor to stop the spindle and use the VFD relay output to engage the spindle brake. I delayed the RO around 4 seconds, which is about double the time my spindle takes to stop from top rpm
    Nov 2008
    147
    I had the resistive brake, and it is only good for quick deceleration, but basically a fire hazard if you want to rely on that for tool changes. I have my VFD send out the signal to my air brake of when to engage. It has a relay programmed to change state when the VFD reaches 0 RPM.
  1. Replies: 3
    Last Post: 04-16-2014, 01:22 PM
  2. Braking resistor for spindle VFD?
    By SwampDonkey in forum Spindles / VFD
    Last Post: 02-27-2014, 04:40 AM
  3. Spindle braking mechanism
    By Rohan2008 in forum Tormach Personal CNC Mill
    Last Post: 09-04-2010, 07:07 PM
  4. Boss Air Brake
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2009, 11:53 PM
  5. Spindle Braking Not Working
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 01-26-2008, 11:15 PM
