586,089 active members*
3,915 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Lynx 220LSY Alarm 2119 Followed by 2147
Results 1 to 7 of 7
    Jul 2014
    I started up my machine this morning it ran one part and now it keeps alarming out with alarm code 2119 (turret index overtime) followed by alarm code 2147 (Servo drive cable open alarm : check the encoder data receive cable of tureet.) Can anybody offer any help as to where this data cable is located?
    If I power down completely it allows me to do one or two tool changes before alarming out again. Thanks in advance for any help.
    Feb 2013
    788
    Re: Lynx 220LSY Alarm 2119 Followed by 2147
    See the attached Technical Document
    It covers all the alarms for the Servo Turret, and describes some minimally invasive tests that can be done.
    2119 and 2147 are both directly covered.
    Toward the back are sections that show how to check the cables.
    Attached Thumbnails Attached Thumbnails COM_Doosan Servo Driver Alarm Manual(rev A)_120710.pdf
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Sep 2012
    We are having this same set of alarms.
    Feb 2013
    788
    Quote Originally Posted by Nate8409 View Post
    Was the attached document able to help you?
    Sep 2012
    Quote Originally Posted by dhardt View Post
    The flow chart is helpful. At least I think so but sadly we are dealing with an under warranty machine. I feel stupid saying that but the company who is supposed to service it thinks it is a timing error and says they literally need to watch the alarm happen in real time to be able to know which cable is bad or if it requires a motor or drive or maybe cables. They did their version of checking the cables.
    Our alarms are random. Recently in the middle of a program. Other times after the machine would sit for a while it would happen which to me says Drive issues.
    Feb 2013
    788
    Your local dealer, 2SQ/Syracuse Supply, has very good service techs. They know how to use TRACE to record selected inputs and outputs, and use the alarm as the stop-trigger. That way, the signals can be diagnosed in 8ms sections.
    Feb 2013
    788
    I have added the instructions for TRACE to the thread http://www.cnczone.com/forums/daewoo...bulletins.html.
  1. doosan lynx 220c spindle rotation alarm no. 2028
    By varskmachinellc in forum Daewoo/Doosan
    Last Post: 11-01-2022, 10:55 AM
  2. Doosan Lynx 220 , Alarm 2118
    By Paugan in forum Daewoo/Doosan
    Last Post: 10-10-2018, 02:51 PM
  3. 2119 Turret index overtime
    By Monty83 in forum Daewoo/Doosan
    Last Post: 08-11-2015, 10:58 PM
  4. servo alarm 51(current command exceeding) on Lynx.
    By Chuck Reamer in forum Daewoo/Doosan
    Last Post: 02-01-2008, 12:11 AM
