603,397 active members*
2,544 visitors online*
Thread: mix match
    Aug 2013
    mix match
    I would like to run a micro proto controller with a Linux - emc2., which is now running my sherline lathe . If I change the pins and ports and motor tuning etc would it work ?
    Hope someone can help
    Apr 2004
    5948
    Re: mix match
    Are you trying to run a lathe or a mill with this controller? EMC works pretty much the same as Mach3, so it should be possible to set up as long as you know which pins control which motors. But there's not a lot of tech support available from LinuxCNC, so you're going to have to figure some stuff out yourself; it tends to ask a lot of questions you won't know the answers to.
    Andrew Werby
    Website
  1. Need to match VFD to HSD Spindle?
    By firstyear in forum CNC Machine Related Electronics
    Last Post: 09-08-2011, 03:36 PM
  2. Trying to match this finish.
    By Kalvin in forum Material Machining Solutions
    Last Post: 02-11-2011, 04:23 PM
  3. DLL Version does not Match
    By spotbox in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-20-2009, 02:39 PM
  4. H&T don't match?
    By Donkey Hotey in forum Haas Mills
    Last Post: 03-24-2008, 02:30 AM
  5. X1 and X2 mix and match
    By acondit in forum Benchtop Machines
    Last Post: 12-05-2005, 10:11 AM
