586,100 active members*
3,089 visitors online*
Results 1 to 9 of 9
    Mar 2013
    17
    Question Mori Seiki SL1 Yasnac 2000B Alarm 28
    After having been producing parts daily with no issues, after having been sitting powered down for less than a week my SL1 wont fully power up. It did initially, but X wouldnt zero return. Now I cant get past alarm 28 which the manual describes as "system unready". It has been really cold for the past week, maybe that's an issue? Help please!
    Feb 2009
    6028
    Re: Mori Seiki SL1 Yasnac 2000B Alarm 28
    Leave it on for a few hours then cycle the power and try again, old machines with old capacitors don't like the cold.
    Mar 2013
    17
    Okay, I'll do that right now. Thanks, I'll let you know how it goes.
    Mar 2013
    17
    Didn't work : (
    Jan 2015
    42
    Did you try to reset all breakers in both cabinets. Machine unready can also be related to any overload or breakers that are tripped.
    Mar 2013
    17
    Quote Originally Posted by ncbobbys View Post
    It seems that it was caused by relays failing to contact.
    Quote Originally Posted by SadieD View Post
    I know this an old thread but I have SL1 lathe that is having the same problem.What location was the relays I’m trying to zero in . Any help is much appreciated .
    Quote Originally Posted by Makinchips24 View Post
    Any update on this fix? My sl-1 is doing the sane thing!
    I been down fir a month trying to figure out why nothing
    Is turning on!
    Jun 2018
    4
    Quote Originally Posted by Adamsmetalshop View Post
    Is turning on!
    Hi the problem is related to mechanical initial conditions, the turret and chuck should be clamped. You can force the hydraulic valves, and clamp them.
  1. MORI SEIKI SL-3 YASNAC LX1 CONTROL ALARM 362
    By WMSMFG. in forum Mori Seiki lathes
    Last Post: 05-18-2013, 01:24 AM
  2. Mori Seiki CL-20 Yasnac LX3 Alarm 330 & 310
    By Nevronplastics in forum Mori Seiki lathes
    Last Post: 01-16-2013, 11:37 PM
  3. Mori-Seiki SL-0 / Yasnac LX1 Alarm Code 332 Help!?!
    By larrynsr in forum DNC Problems and Solutions
    Last Post: 01-11-2013, 09:46 PM
  4. Yasnac 2000b Parameters Mori Seiki
    By thespindoc in forum Mori Seiki lathes
    Last Post: 11-20-2011, 02:00 PM
  5. MORI SL-3A YASNAC 2000B CONTROL
    By JY`S MACHINE in forum Mori Seiki lathes
    Last Post: 05-04-2010, 04:09 PM
