586,655 active members*
4,036 visitors online*
Results 1 to 9 of 9
    Sep 2011
    8
    Question Disabling C axis on Fanuc 21i-MB
    Happy new year from Finland!
    We bought used Stimin FPH-800 milling machine. There is some problems with C axis and I'd like to temporarily disable it.
    On other machine we have, we only need to change parameter 1023(C) to -128.
    I have changed these parameters on FPH-800:
    0012.7 (C) -> 1
    1005.6 (C) -> 1
    1005.7 (C) -> 1
    1010 -> 3
    1023 (C) -> -128
    When cables of C axis are detached I get servo alarm on Z axis:
    401 SERVO ALARM : Z AXIS VRDY OFF
    Can someone help?
    Regards,
    Niko
    Dec 2012
    395
    Re: Disabling C axis on Fanuc 21i-MB
    Hi Niko,
    On our YCM 21i-M it's parameter 9900, change 4 to 3 to disable 4th (A) axis.
    Check this one or one in the 9900-series.
    Regards,
    Heavy_Metal.
    Aug 2011
    2517
    that parameter only sets the total number of axes. if A, B and C existed and only B needed to be disabled it wouldnt work.
    there's a way to select a specific axis but the info is generally not public (via option parameters) because it would allow people to add an axis without paying Fanuc. the Descriptions Manual lists the existence of it as 'Removal Of Control Axis; Parameter; Option'
    Dec 2012
    395
    Hi fordav11,
    At my Fanuc 21i-M control I also have to set some parameters to select the 4th-axis On and Off.
    A technician told me a simple way to do this by parameter 9900, change 4 to 3 and back.
    Now it's very quick and easy to disable the 4th-axis.
    Thats why I suggested the 9900 parameter, at his control maybe an other number.
    Regards,
    Heavy_Metal.
    Sep 2011
    8
    Problem was solved with Fanuc technician long time ago. I'd still like to share the solution. Parameters 2009/C.0 and 2205/C.2 is set to 1 and dummy is attached to servo amplifier, I will add a connection diagram for the dummy later.
    -Niko
    May 2018
    26
    Quote Originally Posted by nikonie View Post
    -Niko
    Would you please share the dummy connection. I also need to use one axis on 3 axis servo amplifier just for testing.
    Sep 2011
    8
    Here is some pictures of the dymmy, two pins needs to be connected together. I don't have time to solve what pin numbers these are.
    Attachment 424708
    Attachment 424710
    -Niko
    May 2018
    26
    Thank You
    Oct 2015
    Dear Niko,
    thank you very much for this advice. After that I've looked to the B-65270EN/05 Drives Parameter manual and found special note regarding disabling axis in multi-axis amplifier.
    "How to Use the Dummy Feedback Functions for a MultiaxisServo Amplifiers When an Axis Is Not in Use" - install Jumper between pins 11 and 12 and set 2209 bit 1 to 1 (in case of only motor encoder Feedback) and 2205 bit 2 (in case of separate feedback like glass scale).
    it's exactly what you've done with serviceman from Fanuc.
    Just tested on my 0i-MC and succesfully remove rotary table axis. Will make new encoder cable for it and install back.
    Thank you!
  1. 4th Axis disabling (Fanuc 0-M)
    By Richard Horton in forum Fanuc
    Last Post: 07-04-2023, 09:01 AM
  2. Disabling single axis on G540
    By fer_mayrl in forum Gecko Drives
    Last Post: 12-15-2010, 10:28 PM
  3. Replies: 2
    Last Post: 04-07-2010, 02:46 AM
  4. Disabling A-axis, horizontal mill
    By teal854t in forum Haas Mills
    Last Post: 03-24-2009, 12:56 AM
  5. Disabling Help Wizard
    By kentavv in forum Mach Software (ArtSoft software)
    Last Post: 02-20-2007, 05:40 AM
