586,076 active members*
3,740 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > output probe data to a new program file
    Apr 2014
    44
    im trying to output the probed hole positions to a new program file.
    lets imagine that that i have 10 parts in a program with 4 predrilled holes per part that need to be tapped.
    my tapping cycle for tapping the holes would look like this:
    G71 Z0.2
    G95
    G84 X0.5 Y4.7879 Z-0.25 R0.2 F0.0179 S1568 M53
    X1.8911
    Y3.5
    X0.5
    X1.8911 Y1.7879
    X0.5
    Y0.5
    X1.8911
    X4.8911
    X3.5
    Y1.7879
    X4.8911
    ETC......
    G00 Z0.2
    but those hole positions are out by max 0.025 due to fixture imperfections.
    so what i would to do is rewrite the program using the position data and have to probe find the center of the hole and output the x and y coordinate data to a new file on our okuma MB56va machine with a p100m control.
    mostly what im looking for is a method for outputting probe data and append it to the end of a .MIN file so i can copy and paste the new location data to the tapping cycle. i don't have any renishaw probing software, all i
    use is the software okuma ships with their machines. i use the following gcode line to do a hole search: (G114 PD=0.4 PW=1) where PD = approximate hole diameter and PW=work offset.
    and here is what the hole finding program could look like....
    G40 G80 G90 G94 G17
    G20
    M09
    G116 T32 (probe)
    G15 H01 (work offset)
    G00 X0.5 Y4.7879 (rapid to first hole)
    G56 Z0.85 H32 (Tool offset, rapid to Z position) (is there a way to make protected rapid moves with okuma's built-in software? even though i will try to run this in maybe 1or5% mode)
    Z-0.2 (rapid into hole)
    G114 PD=0.4 PW=2 (probe hole and send offset to currently unused work offset)
    G15 H01 (reselect work offset 1)
    (now i need something to save this XY location from workoffset 1 to a new .MIN file.
    G00 Z0.85 (rapid out of hole)
    G00 X1.8911 Y4.7879 (rapid to second hole)
    Z-0.2 (rapid into second hole)
    G114 PD=0.4 PW=2 (probe second hole)
    G15 h01 (reselect work offset 1)
    (update or append second hole data to the .MIN file)
    M09
    G90
    M02
    thanks!
    Jul 2010
    287
    Re: output probe data to a new program file
    First and foremost, I think we need to see some different code to understand exactly what your program is doing.
    G114 is not a probing cycle per se, it is a G code macro call. Your probe cycle would actually look something like:
    CALL OO16
    CALL OO10 PMOD=7 PDI=8
    CALL OO20 PHN=(X)(WORK OFFSET LOCATION GETTING SAVED TO A WORK OFFSET NUMBER) PX=(X) PY=(X)
    CALL OO19
    The program is probably saved in a .LIB program of some sort. Some people name theirs more literally something like OG114.
    That will tell us what your G114 code is actually doing.with the probed positions.
    Second, why do you need the data to be saved to a .MIN file?
    I can push local variables to a .SSB file, but i've never tried to do it to a . MIN through a schedule program, but i'm 99% sure you cannot do this.
    I CAN save the values to a common variable which I can reference from a different .MIN altogether, but I wouldn't be actually populating an X/Y position so much as storing one as VC1=VAPAX or some such thing. If your probe cycle is sending to a tool offset it'll probably be sent to VTOFH[offset number] so you'd see VC1=VTOFH[56] or whatever that value is.
    Now, if there is a varying number of holes, you can have something like
    G71 Z0.2 (You can remove this as well as the M53 since your R value is the same)
    G95
    G84 Z-0.25 R0.2 F0.0179 S1568 M53
    IF HO1 NHO1
    NHD1
    IF HO1 NHO2
    NHD2
    IF HO1 NHO3
    NHD3
    IF HO1 NHO4
    NHD4
    GOTO NEND
    NHO1
    X=VC1 Y=VC2
    GOTO NHD1
    NHO1
    X=VC1 Y=VC2
    GOTO NHD2
    NHO3
    X=VC1 Y=VC2
    GOTO NHD3
    NHO4
    X=VC1 Y=VC2
    GOTO NHD4
    etc...
    NEND
    G0Z100
    I cannot recall if you can do a logical statement inside the Tapping cycle, you can during a lathe LAP cycle, but mills are different in some things,, but that's what modin and custom sub programs are for.
    Moral of the story, I need more data to help, and there's always a way.
  1. using a data file for both 3D printer and CNC router , Converting file or ???
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 12-17-2014, 01:32 AM
  2. Help with data output 31i fanuc
    By KyDeano in forum DNC Problems and Solutions
    Last Post: 05-23-2013, 03:25 PM
  3. Undrestanding G38.2 probe file output
    By bogflap in forum LinuxCNC (formerly EMC2)
    Last Post: 03-05-2009, 03:43 PM
  4. Probe output data??
    By mgb1974 in forum Haas Mills
    Last Post: 10-31-2008, 04:20 PM
  5. "wrong program data" when file transfer????
    By spock in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2008, 11:59 PM
