586,105 active members*
3,221 visitors online*
    Jan 2012
    10
    New 8020 frame CNC Mill
    Good evening everyone I have been lurking around this site a while but I figured I would share my build as others have done. 2 years ago I did build a smaller 80/20 mill so that I can mill some aluminum parts for my telescope equipment, it was a 12x18 moving bed machine.Attachment 264226.
    I had done some relief work in wood and fell in love with it so started planning on a bigger machine as I had requests to do signs. So here I am with the start of the build and some questions to boot also as all this stuff is self taught. Never did any machine work in my life I am a computer geek.
    So I wanted to do a moving gantry this time and a large cutting surface so decided on a 24" x 48" inch machine, that was 80/20 framed with linear rails. So on Ebay I went and started looking for linear rails with carriages and after about 2 weeks I got luck and found a pair of 48" linear rails with 4 carriages. After getting them I took them all apart de-greased them and used the grease I use on my telescopes that allows for smoother motion. I had to put things on hold as Christmas was coming up and well with 2 kids and a wife, I can't just keep buying myself stuff. After Christmas I got back on ebay to look for 24 - 36" linear rail with carriages for on the gantry. Again I was in luck and got a 31" rail with 2 carriages, then started looking at the 8020. I was going to go with 2040 material but decided on the 3030, plus I found a great deal on 2- 56inch 3030 with the ends tapped already. This was was perfect as it allowed for a longer table so I can have just about a 48" cutting area. For the gantry arms I am using 1545 and found a piece 59" long for a cheaper price then 2 - 24" 1545 pieces. I am debating on if I should allow the X axis to be adjustable in height if need be or make it stationary. At first I was thinking of going R&P but I think I am going to go with ball screws instead, thoughts? I bought 2 - 6" x 6" x 5/8" aluminum to use as a connector plate between carriages and 1545. This is what I came up with
    Attachment 264234.
    Well that is what I have for now welcome any comments and thoughts.
    Bob
    Jan 2012
    10
    Re: New 8020 frame CNC Mill
    So I was originally going to only use one linear rail with 2 carriages on it, but I see others have a dual system. So I am in search of either another one like I have or another dual rail/ carriage system.
    Apr 2015
    A bit off topic, but I'm curious how your first machine worked out for you and what you liked/didn't like about it (other than size). I'm considering a similar build myself. Aluminum extrusion frame, fixed gantry, moving table. I'll mostly be machining aluminum or wood. I'm also hoping to have a decent Z height to facilitate swapping the spindle for a extruder head and using it as a 3d printing platform. Anyway, I like the look of your old build and curious how it worked out for you.
    As for your question about 2 rails vs one, is that for your Y or X axis? I see in your photo you have the gantry bolted directly to the bearings on the Y axis with the rails mounted on the sides. I've gotten the impression in my research that if your rails and bearing blocks have 4 races you should be OK with a single rail for an axis. If they are only 2 races you may want 2 parallel rails. I'm also wondering if you'd be better off having the Y axis rails on the top of your extrusion so the weight of the gantry pushes down on the top profile rather than the side profile?
  1. 8020 Mill enclosure
    By Thorpydo in forum Benchtop Machines
    Last Post: 03-10-2010, 07:30 PM
  2. 8020 CNC mill enclosure
    By VTX in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 01-24-2007, 01:18 AM
  3. Gantry VS. C frame for metal mill
    By Tristar500 in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2006, 12:48 PM
