603,853 active members*
3,473 visitors online*
Results 1 to 7 of 7
    Mar 2013
    14
    Tornado A90 with MBF-1000 M19
    I am trying to feed hex bar on an A90 with MBF-1000 bar feed. Using M19 can I specify the rotation angle or is this fixed somewhere in parameters and if so where?
    Any help would be very much appreciated...
    May 2016
    533
    Re: Tornado A90 with MBF-1000 M19
    Clive
    You stipulate the angular rotation in the barfeed page accessed by pressing custom Graph
    If you still cannot find it call me at the RK office and I'll talk you through
    Darren
    Tel 01322 447611
    Mar 2013
    14
    Quote Originally Posted by rkservice View Post
    Clive
    Darren
    Tel 01322 447611
    Thanks Darren - I must be blind ! Will I have to lock the collet in position in relating to the chuck for this to work consistently (to prevent the collet rotating in the chuck when unclamped) ?
    Regards
    Clive
    May 2016
    533
    It depends on how much the collet opens however to be safe i always pin the collet chuck clamp plate to stop movement
    Apr 2010
    45
    You can set it in the Bar feeder page after it has homed..............
    Hello, can you send me a message and I will help you install parameters?
    Apr 2010
    45
    Hi Salih what is the serial number and the electrical diagram number
    nsafos@canadianmachinetools.ca Phone number 1 647 308 3375
    Nick Safos
  1. Tornado 200
    By cgjohn in forum Colchester Tornado lathes
    Last Post: 08-16-2018, 09:47 PM
  2. Tornado 200
    By hmc710 in forum Colchester Tornado lathes
    Last Post: 06-09-2010, 10:27 PM
  3. tornado 80
    By kirkchabot in forum Colchester Tornado lathes
    Last Post: 01-04-2010, 08:51 PM
  4. Tornado T4 Lathe
    By espinja in forum Colchester Tornado lathes
    Last Post: 11-30-2009, 03:33 PM
  5. tornado 100
    Last Post: 12-23-2008, 02:10 AM
