We have an old vertical that ran on a dos program. I'm in the process of converting it to KmotionCNC using Kflop/Kanalog to control the servos and VFD spindle.
The servos are Glentek. The drives are Glentek GA377-1. I had contemplated using gecko drives but everything is already there.
Two things are puzzling me....so far.
#1 When I enable the drives, I'm used to the servo's basically locking up. You can't move them by hand. When I enable the drives on this machine, I AM able to move them. The try to return to the original position, but I can move them kind of easily.
#2 After each test, it doesn't always return to the same position. It's always 1-3 counts of on the Axis tab.
Attachment 264438
