586,551 active members*
3,409 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Lag time on slaved stepper?
    Jul 2014
    59
    Here's the issue. One of my steppers on the X axis has a little lag time when moving. The X is made up of two motors on a R&P system. When I make movements one of them doesn't immediately move but when it does catch up everything is fine. Tuning isn't a problem...checked that. Is it possible to get backlash in a R&P system? Can I make a change in Mach? It seems like the response time is a hair off.
    Re: Lag time on slaved stepper?
    Is backlash compensation enabled?
    Jul 2014
    59
    No Gerry. I just have started having issues so before I changed things too drastically I wanted to ask around. I didn't know if backlash was a product of the motor or something else. I don't have homing switches to square things up....will that change how I set up backlash compensation?
    I have no idea, but that's the only thing I can think of that would cause a delay on one side.
    Jul 2014
    59
    Okay Gerry....I just checked things out. I tried the backlash compensation and that didn't do so well. I checked things out and found that the gear had not gotten tightened up so it was a mechanical thing.
    I've still got an issue that I'm going to post in another thread.
  1. Can servos be slaved?
    By rybov in forum Linear and Rotary Motion
    Last Post: 03-11-2012, 09:25 PM
  2. Slaved stepper axis out of sync (Lag) Mach3
    By LazyMan in forum DIY CNC Router Table Machines
    Last Post: 12-30-2011, 01:53 AM
  3. stepper motor driver speed problem , PLZ read one time
    By sizala in forum Hobbycnc (Products)
    Last Post: 01-31-2011, 07:51 AM
  4. stepper or servo for first time.
    By the4thseal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-24-2009, 06:45 AM
  5. What time does it take to a stepper to reach 600 rpm ?
    By cnc2 in forum Stepper Motors / Drives
    Last Post: 01-12-2009, 05:59 AM
