586,075 active members*
4,255 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Hawk 150 Machine Power Up Issue After Changing Cmos - A2100 Control
    Oct 2012
    8
    Hawk 150
    A2100 Control
    1. Machine would not turn on - blank screen with a 1"x1" square in the center of the screen.
    2. Changed cmos battery, reset time and date and checked cmos setup parameters.
    3. Machine boots fine but is missing keyboard/touch screen. We have a mouse and keyboard hooked up to get past the touch screen not working.
    4. Here is the problem, besides the touch screen not working everything seems fine, when I go to power the machine On by pressing the green button nothing happens. I have tried checking the I/o board but it is not reading the slot/rack numbers.
    Is there away to power on the machine other than pushing the green button?
    Oct 2012
    8
    Re: Hawk 150 Machine Power Up Issue After Changing Cmos - A2100 Control
    Also there are no alarms on the screen. Everything seems fine except for the touch screen and buttons not working. Before the cmos battery died the touch screen worked.
    Dec 2006
    584
    Why did you change the 2032 battery on the WORKSTATION board (far left) ??? Did you also change the 2032 battery on the REAL TIME BOARD (far right)??? How do you know the BIOS (cmos) settings are the same???
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Nov 2010
    12
    Hi dear.
    I have a Cincinnati Milling Machine. With Acramatic 2100 control. I had a bios battery message. And the clock was constantly erased. I changed the battery on the ws board. Unfortunately, I have ws fail alarms. And does not work.
    This ws board model is: aa 670917-310
    Do you have bios settings?
    please guide me .
    my email : [email protected]
    Thanx
  1. Hawk 150, A2100, machine power quits, no error message
    By blackbolt9 in forum Cincinnati CNC
    Last Post: 06-24-2014, 08:25 AM
  2. prima power platino machine issue
    By coolkarthi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-06-2013, 10:32 AM
  3. Hawk 5M Power Cabinet OverTemp
    By HurcoUser in forum HURCO
    Last Post: 02-13-2012, 04:21 PM
  4. R2V3 power up issue Boss 10 control
    By wcarrothers1 in forum Bridgeport / Hardinge Mills
    Last Post: 05-18-2009, 07:07 AM
  5. Fanuc 10TF Control Power Issue
    By rbleth51 in forum Fanuc
    Last Post: 08-20-2007, 08:22 PM
