603,890 active members*
2,675 visitors online*
    Mar 2013
    5
    CNC Vertical Milling machine DIY
    Hi there I've been browsing this forum for a few years. I've had a couple CNC machines. My first one was a buildyourCNC book machine that my brother gave me to play around with. After that I bought a Grizzly G8689 and converted it to CNC with a CNCFusion kit.
    I ended up selling the X2 a year or so ago because of finances etc and I've been wanting another mill for some time... I've searched and searched but nothing I've found does what I want it to do... and as a DIYer I wanted to build my own machine. Soooo I've started my Search and started buying parts.
    I'm basing this machine off of other DIYers builds as I've found a few I like alot but wanted to change some things about the designs.
    So here goes!...!
    I'll update as parts come in and as i start assembly.
    Mar 2013
    5
    Re: CNC Vertical Milling machine DIY
    So far this is what I've got.
    2: 3030 15 Series extrusion for the Y axis
    1: 3060 15 Series extrusion for the Z axis
    2: 3030 15 Series extrusion for the Z axis
    2: sbi25sl 25mm Linear rails that measure 19 3/4" (Z axis)
    2: INA kwve 30mm Linear rails that measure 23" (I'm probably not going to use these as I cant find the blocks for a decent price $175 for 1 block, ouch)
    I plan on having 18" Y travel, 11" Z travel and 24" X travel.
    Attachment 266544Attachment 266546Attachment 266548
    Jan 2008
    458
    I see you picked up a couple of feet for your bench.
  1. Looking for buy a cnc vertical milling machine
    By Eluis in forum Want To Buy...Need help!
    Last Post: 04-03-2011, 08:54 PM
