588,500 active members*
5,271 visitors online*
    Nov 2005
    244
    4th axis continous rotation
    I am looking to turn a simple alumium part or a machining center with a Fanuc 16i control. The rotary table is a full 4th axis. The material is alumium with .010 coming off the I.D.
    Is there a way write code that is not real long to have the rotary table turn at a continous RPM of say 1200 and feed Z-3.00 at a feedrate of .008 I.P.R.?
    Thank You
    2932
    Re: 4th axis continous rotation
    Do you know the max. programmable feedrate of your 4th axis?
    I've just looked at a couple of examples, and max was 88.9 RPM on one and 30 RPM on the other. I'd be surprised if your 4th axis will feed anywhere near 1200 RPM.
    I believe the maximum programmable rotary dimension on a 16i is 99,999.999 degrees, and the maximum programmable rotary feed is 240,000 degrees/minute.
    Your example of 1200RPM would require a programmed feedrate of 432,000 degrees/minute, so I don't believe you can get there from here... but I could be wrong.
    Aug 2011
    2517
    you are correct. it is not possible to do real lathe 'turning' with a 4th axis rotary table.
    this is the primary reason why multi-axis turn-mill machines are popular.
    FYI the same question has come up here a few times and similar answers were given.... either turn it on a lathe first or get a turn-mill machine.
    You have to run your 4th axis as a PMC controlled axis. You will have to modify the ladder to do this. Also, you must add an M-Code to activate the 4th axis as a PMC controlled axis and anther M code to revert back to CNC controlled axis. And most important like Dcoupar says, make sure your 4th axis can safely handle those speeds.
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Continous 4 axis = XZA or must be XYZA motion capable?
    By bebob1 in forum Uncategorised CAM Discussion
    Last Post: 02-14-2012, 12:05 PM
  3. Rotation along the y axis?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 07-09-2010, 05:27 PM
  4. B axis rotation
    By fitzpatrick2362 in forum MetalWork Discussion
    Last Post: 10-12-2009, 12:06 PM
  5. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-18-2006, 02:36 AM
