603,939 active members*
2,553 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > Dynapath Delta 10 Lathe- M10 collet close command not working Help
Results 1 to 7 of 7
    Feb 2015
    4
    I have a Dynapath Delta 10 lathe and I am setting up a barfeed. The Collet open and close switches work as they should opening and closing the collet. When running a program, the collet open command opens on a M11 command. However nothing after the M11 command works, especially the M10 collet close command. I know the open collet prevents the machine from being started, so is there another command that I need to enter before the M11 command? Also, I've tried all other possible collet close commands, but nothing works after the M11 open command anyways.
    Feb 2009
    6028
    Re: Dynapath Delta 10 Lathe- M10 collet close command not working Help
    You probably need to adjust a prox switch on the chuck actuator, its probably waiting for a finish signal from M11
    Feb 2015
    4
    Thanks for the response underthetire. There is only 1 wire to operate the solenoid for the close collet. So the same wire operates the close collet from the switch or the m10 command. It operates fine from the console switch.
    Feb 2009
    6028
    Do an MDI command and see if the cycle start stays lit. If it does, its waiting for a finish signal from somewhere.
    Feb 2015
    4
    Quote Originally Posted by underthetire View Post
    I did and the light goes out after the M11 collet open command. Its as if it needs another command before M11?
    Feb 2009
    6028
    Are you still in feed per rev mode? If so you will need to be in feed per minute since the spindle is not rotating.
    Feb 2015
    4
    ok I added a G94 to change to fpm. Still the same thing the light goes out after the M11 collet open. BTW , thanks for all your help.
  1. Replies: 0
    Last Post: 09-05-2011, 09:00 PM
  2. Replies: 0
    Last Post: 09-05-2011, 08:57 PM
  3. Dynapath Delta 20 Lathe Controller
    By elnerdo in forum Dynapath
    Last Post: 12-12-2009, 02:36 AM
  4. DynaPath Delta 2000 Lathe
    By eneet in forum DNC Problems and Solutions
    Last Post: 04-07-2009, 01:29 PM
  5. What M Codes open/close your lathe collet ??????
    By nelZ in forum Uncategorised MetalWorking Machines
    Last Post: 09-05-2008, 02:28 PM
