586,067 active members*
5,239 visitors online*
    Jan 2015
    5
    convert G-Code to PGM
    Hi¡¡¡
    I need to convert G-Code to PGM I tried to winxiso but I could not
    Does anyone know of a method to do so?
    Thank You
    Quote Originally Posted by jmpluk View Post
    Hi¡¡¡
    Thank You
    I had to find out what a PGM file was first. :-)
    So, Your G-Code will direct a cutter of a known dia along a path and you want to create an image using that data and assigning a shade of grey to the path which is dependent on the depth of cut? And subsequent passes of the cutter will make the shade of grey darker, over writting whatever is already there?
    Have I understood correctly?
  1. convert G-Code to HPGL
    By feraldave in forum Uncategorised CAM Discussion
    Last Post: 10-14-2008, 02:48 PM
  2. Help Convert .dfx to g-code please?
    By jsnbrgg in forum G-Code Programing
    Last Post: 11-29-2007, 06:02 PM
  3. Can someone convert it to G-code for me ?
    By rceebuilder in forum BobCad-Cam
    Last Post: 11-10-2006, 10:56 PM
  4. How to convert 3D model to G-code?
    By Peten in forum Uncategorised MetalWorking Machines
    Last Post: 10-13-2005, 09:57 PM
  5. Convert to G-code files
    By quickerz in forum Solidworks
    Last Post: 05-30-2004, 05:55 PM
