586,060 active members*
4,158 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alphacam settings issue.help?
Results 1 to 7 of 7
    Feb 2015
    7
    We recently formated our PC and with it we lost the settings of the software Alphacam. Now we are having issues when exporting .anc files from Alphacam and importing at the milling machine. We made photos of all the errors we get on Alphacam and the milling machine computer.
    Since this problem happened in a very critical moment, ( we have an advertising campaign from a very respected client) we will need someone to help because its a little urgent. ( we are trying, but unsuccessful till now).
    Thank you in advance
    May 2011
    108
    Re: Alphacam settings issue.help?
    You could start by doing as it's telling You - apply lead in/out (and of course, check that the correct Postprocessor is chosen)
    Feb 2015
    7
    Quote Originally Posted by camnerd View Post
    Thank you for your answer.
    Since I'm not very familiar with the machine, I don't know where to check the Postprocessor settings. Can you please advice me more on this topic?
    Thanks in advance.
    May 2011
    108
    when choosing "save NC", You can see on the first page, what Postprocessor is active..
    if it's not the correct one, You can go to choose the right one (supposed, that You have this )
    Feb 2015
    7
    Hello again camnerd,
    Thank you for your suggestion on the postprocessor.
    Yesterday I advanced my knowledge on that topic. I now remember that yes, I have the correct Processor. I found how to change them and I even edited it with AlphaEdit because it wouldn't allow a SpindleSpeed of 18000 , which it did allow before formatting the PC. There are no errors upon exporting now but still they dont work at the router.
    BUT, at the router we have the old files .anc that work. I saw one of their g-code and they say things like : G43, G54 etc...More than 40 lines of code. Whereas at the files I export now they dont have any line that has G in it and they are just 7 or 8 lines.
    How to get G-code on files ?
    Thank you in advance.
    May 2011
    108
    I think, You should contact Your reseller - (or are you not on the SMP?)
    Oct 2013
    109
    It sounds very much like you lost your post processor when you formatted your hard drive. As posts are customised you will need to contact Alphacam to write you another one.
  1. Replies: 1
    Last Post: 09-10-2014, 01:05 AM
  2. AlphaCAM v5 and Anderson Stratos Issue
    By mrneelix in forum Uncategorised CAM Discussion
    Last Post: 01-15-2012, 01:44 PM
  3. AlphaCAM 00 and AlphaCAM V5 - same postprocessor
    By Ziyan in forum CNC Machining Centers
    Last Post: 10-10-2011, 12:59 AM
  4. Alphacam Router Z value issue
    By celtic1967 in forum Mastercam
    Last Post: 09-18-2011, 05:51 PM
  5. An EZTROL Issue in Settings
    By Mihelich in forum Smithy
    Last Post: 06-13-2009, 07:25 PM
