603,314 active members*
2,043 visitors online*
    Sep 2006
    14
    Boss 8 to Mach Conversion Help
    Everything seems straight forward except servo drive choices. The stock current drivers are NC400 units with 30 Amp capability. The factory Power Supply puts out 100 Volts DC and I would like to reuse this in my conversion. 100V @ 30A is more than a Gecko drive can handle. I looked at Rutex, there inventory seems to be low, makes me a little nervous. They have a board (R991H) that looks like it will take step/dir and the encoders and put out a +-10V signal to the stock NC400 Current Amps. Anybody use these? How about the R90H? Any other low cost servo drives out there? I am an electrical engineer (and a technition before that), so I "Aint Sceered" to try ideas.
    I also need the encoder pinout, they have 10 pins (5 twisted pairs, all the same color in the cable).
    Any help would be appreciated.
    TurboStew
    Jan 2006
    204
    There was a thread started on
    mach1mach2cnc@***********.com
    at 10/21/2006 at 12:37 am
    about this topic
    Happy Hunting
    archie =) =) =)
    Jan 2006
    204
    That was on Yahoo
    archie =) =) =)
    Jun 2003
    866
    There is another step/dir to analog converter
    http://www.skyko.com/products/
    Someone here got it working, don't know anything else about it.
    Aug 2005
    828
