603,969 active members*
1,535 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Drive Pasific scientific 6410
    Mar 2015
    5
    Exclamation Drive Pasific scientific 6410
    Attachment 271050Attachment 271052Attachment 271054Attachment 271062
    hi!! everybody !!
    My name is arny!!:and I'm not speak english ,, sorry ,, Im just write a few many wrotes. I hope and you can help me !!
    Im a new guy in the forum so..
    I buy a tree drive and steppers motor ,,
    this is the dates of the motor and drive´s
    Motor:
    Power Max II 1.8° STEP motor
    Model; P22NSHS- LNN NS-02
    Cust.T/N: I(DC): 3.1 A Bipolar paralle VS: 35v
    PO: 58 W
    T 90° C max
    1500 RPM.
    Drive:
    Model No.: 6410- 030-N-N-N
    Pasific Scientific S/N: 03C- 1544.
    Pin 1 Step +
    pin2 Dir +
    Pin3 Enable +
    Pin 6 Step-
    Pin7 Dir-
    Enable-
    I download the data sheet of the drive but my problem is the nex
    they have a
    Pin 1 Step +
    Pin 2 Dir +
    Pin 3 Enable +
    Pin 6 Step-
    Pin 7 Dir-
    Pin8 Enable-
    I test the drive with the motor connection to voltage source 24 volts, and with a 5 volts test the voltage pulses
    Pin 1+ 5 volts and Pin 6 -vcc the motor move,, , so when want to change the motor direction this does't make the change.. I make the test to tree drive ,, so ,,
    please help me ,!! ,,,
    I think I do wrong something
    gracias
    alguien habla español?
    1695
    Re: Drive Pasific scientific 6410
    What are you using to generate the step signal?
    Each pulse to the step pin will make the motor move 1 step and then stop.
    The level on the DIR pin controls the direction. 0 = forward, 1 = backward.
    Mar 2015
    5
    Talking Re: Drive Pasific scientific 6410
    Quote Originally Posted by H500 View Post
    Hi,, friend,! thanks for re- post me,, ok ,,
    the signal pulse I make with my usb ,, yesterday I was watching on the manual and I make the test like the page 36,, and,,, woo0,, the motor make the change ,, but in Match3 ,, noo!!;, and, I dont now,, how, !!,, can you help me,!! maybe tomorrow ,, upload some pictures,,!!!
    so,,, really,, really ,, thanks very much ,, :rainfro::wave: H500 ,, as people like you ,, the world is the best !!
    1695
    I think the problem is that you are using a usb to parallel converter. That will not work. Mach3 will only work with a built-in or PCI parallel port. If the laptop don't have one, you will need to buy a special USB motion controller board such as Smoothstepper.
    If your application is simple, you might be able to use grbl instead of Mach3. It will run on a $3.00 arduino nano board.
  1. pacific scientific true treadmill brushless servo drive pc2302-010 help
    By arlynjames in forum CNC Machine Related Electronics
    Last Post: 05-21-2019, 04:09 PM
  2. kcam and pacific scientific 6410 driver
    By tc2468 in forum Controller & Computer Solutions
    Last Post: 03-04-2015, 04:16 AM
  3. Help needed with Pacific scientific sc320 drive and DPM
    By dannystooblue in forum Servo Motors / Drives
    Last Post: 06-13-2008, 06:07 PM
  4. Pacific Scientific 6510 Drive
    By marshall1 in forum Stepper Motors / Drives
    Last Post: 03-29-2006, 10:27 AM
