586,119 active members*
3,679 visitors online*
Results 1 to 1 of 1
    Feb 2004
    84
    Laminated Beam
    Working on my next router. I was going to build David Steele's larger router using my Z axis build from his plans.
    I was not sure a 2" X 4" gantry beam would work well with my Z axis so I decided to build a new beam.
    I laminated a 2" X 2" aluminum channel to 3/4" fir. I sanded the aluminum, cleaned off any oil and glued with epoxy.
    I will use the same rail system David shows in his plans.
    There is a picture of my old router table that I will use parts off it for my new machine.
    Larry
    Attached Thumbnails Attached Thumbnails Beam.jpg   Gantry End.JPG   Z axis.jpg   My old router.jpg
