588,169 active members*
4,338 visitors online*
    Apr 2009
    3376
    V 27 not opening
    I got the current build of 27 running demo..Using Windows 7
    It seems like every other time I go to open it it won't.That includes double clicking a file,,,double clicking the BoB icon,,R/Click open.
    Open up task manager and there BoB is under process.
    It does not appear to be using any memory,but nevertheless it is listed as a process.
    So if I click on it and end process,I then can open V27.
    Thoughts ???
    Jan 2007
    235
    Re: V 27 not opening
    It might off to one sidw of the screen. In the task BAR is bob there? If it is right click on it and select move. With out moving the mouse click on the left mouse button and keep it down. Then move the mouse around. It might be able to be dragged back into the screen.
    Apr 2009
    3376
    I figured a little out.
    If I don't run simulation,I can close and re-open.
    If I do run simulation and close,,then the next time it won't open.
    Then I go to task manager and there BoB is,,not using any cpu's but it is listed under processes.If I end process I can then open.
    So it appears to hit a snag when simulation is used.
    Not too worried about it,it is only demo,but still......
  1. opening SW dxf or dwg in ver 26
    By spock in forum BobCad-Cam
    Last Post: 12-21-2013, 04:48 PM
  2. Job opening.
    By rhipsher in forum Employment Opportunity
    Last Post: 03-02-2012, 10:24 PM
  3. Job Opening
    By nigjoe in forum Employment Opportunity
    Last Post: 09-20-2011, 02:21 PM
  4. JOB OPENING!!!
    By Pete_Ta1965 in forum Employment Opportunity
    Last Post: 11-30-2010, 02:23 PM
  5. Job opening
    By qnet2 in forum Employment Opportunity
    Last Post: 11-19-2010, 02:10 AM
