586,640 active members*
2,509 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Wiring Config on a JP-3163b board to the A131NBC-8015
Results 1 to 9 of 9
    Mar 2015
    8
    Hello can someone point me in the right direction.
    I want to control the Spindle from Mach3 but not sure what wire goes where.
    Have I got the PWM correct? The C and NO on the controller card I'm not sure where they go on the VFD
    Attachment 274014
    Any Help would be much appreciated
    Apr 2015
    Re: Wiring Config on a JP-3163b board to the A131NBC-8015
    Just got my own (seller sent me the wrong setup : 3-axis with separate VFD & separate stepper controllers). I ordered a 4-axis setup with the single black "box" for all controls. Trying to get the seller to send me the 4th-axis item or work with me otherwise.
    Anyways - did you program your VFD to allow the External Settings? (Pn03 = 4 & Pn04 = 2 .. not sure if Pn28 needs to be set - will test if I decide to keep this 3-axis setup).
    The relay lines appear to need to go to ports 14/15/16 but I haven't dug into it yet to figure out which is for C (common) and which is for NO (normally open) .. ports 14/15/16 are Lk (Relay ON) / Lb (Relay OFF) / Lz (Relay ON/OFF) ..
    I'll keep checking in to see if any guru's and experienced persons post up too.
    Tim N.
    Jun 2015
    I have the same problem
    Did you figure out how to connect the VFD to mach3
    jan
    Jul 2015
    necesito ayuda con el cableado fotografia gracias soy novato Cableado Config en un tablero de JP-3163b a la A131NBC-8015
    Jul 2015
    You have found a solution?
    Dec 2015
    5
    Did you sort out the settings for the Askpower A131 VFD? I can't get mine to work with the external potentiometer despite following the suppliers instructions (in broken english). It's connected to an 800 watt 400hz spindle that will onmly run at half speed with the pot. Any help with the VFD settings would be much appreciated. Mick
    Nov 2021
    3
    Quote Originally Posted by Nubivec View Post
    What is the solution?
    Have you managed to solve this problem? I have had this machine for 5 years now with same setup with Mach 3 and can't seem to turn the spindle on and off. This means I do it manually and it's costing me money leaving spindle running for hours down the workshop! Otherwise the router is great! Thanks Mick
    Apr 2022
    136
    If you VFD controlled by 0-10V and you supply it with PWM signal how do you expect it to work?
    You need to get a controller that supplies 0-10V or a converter that converts PWM signal in to 0-10V.
    Most of VFD I worked with still need to be programmed to accept that signal …
    - - - Updated - - -
  1. Anyone have a config file for HY-JK02-M breakout board?
    By Galane in forum LinuxCNC (formerly EMC2)
    Last Post: 09-22-2013, 02:41 AM
  2. Wiring config (and the maker) of stepper motors
    By janda3178 in forum DIY CNC Router Table Machines
    Last Post: 03-01-2011, 04:20 AM
  3. DM2800 (escap stepper wiring config needed)
    By cncinbama in forum Dyna Mechtronics
    Last Post: 08-09-2010, 11:01 PM
  4. wiring config for RTS/CTS
    By 7xpm in forum Haas Mills
    Last Post: 02-07-2010, 09:13 AM
  5. NEED HELP! with new driver board config
    By Stinkfisst in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2009, 12:25 AM
