586,121 active members*
3,661 visitors online*
    Mar 2015
    simple question about Milltronics vm15
    I do IT support for a manufacturer. I have been tasked with networking a Milltronics vm15 machine running on DOS, so they can upload/download files from/to it. They had their CNC support company physically install the network card in the machine. I wasnt there when it was done, and they left no documentation.
    I just need to know how to exit out of the cnc software to a DOS prompt so I can configure the networking.
    thanks
    Nov 2013
    128
    Re: simple question about Milltronics vm15
    Quote Originally Posted by e1mariem View Post
    thanks
    There are several ways, you can press F-8 right before auto-exec takes effect and follow the prompts using common sense and tell it not to start cnc. If it is already powered up, go to "PARAM" , "SETUP", type "PROTO3", press enter, level 3, enter again, then a DOS key will become active. At this point you can either press the DOS key and exit the CNC into DOS, or escape out to the main menu and go to "DISPLAY" and enter the SHELL, if you enter the shell you can return to the cnc by typing exit at any point. Just remember, most changes won't take effect until a power cycle or at least running auto-exec again.
    Mar 2015
    thanks for your help. I'm obviously a cnc noob
  1. visualmill post for cent6 vm15
    By ihbuilder in forum Milltronics
    Last Post: 01-03-2012, 04:05 PM
  2. Milltronic Vm15 Powermill Postprocessror Need
    By ehsan.amouzegar in forum Milltronics
    Last Post: 03-27-2011, 05:27 AM
  3. milltronics software question
    By bradyplummer in forum Milltronics
    Last Post: 12-29-2008, 04:07 PM
  4. CNC Newbie with Milltronics Question
    By Rcurry23 in forum Milltronics
    Last Post: 08-04-2007, 05:05 AM
  5. Simple Question Simple Answer ?
    By p3t3rv in forum Stepper Motors / Drives
    Last Post: 02-16-2006, 04:00 PM
