603,813 active members*
4,936 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > cincinatti 750 with siemens acramatic 2100
Results 1 to 8 of 8
    Apr 2015
    8
    Hello to everybody,
    i have a problem with the siemens acramatic2100.
    Am trying to pocket mill using G26.1 pocket milling.
    But the diameter is coming out totally wrong,for example,trying to mill a 4 inch dia hole,the dia is coming out at 3.6 inchs.
    Also using helical ramp it is leaving a small dia pip in the middle (easily solved with a seperate op)
    As for the dia problem,have checked and rechecked all parameters,checked the tool table.
    Is there a setting somewhere else that some one may have changed in the past,or do we have a software problem ?
    We have tryed various dia's but with the same result,always coming out smaller than programmed.
    Any help would be appreciated,
    thanks,
    Paul.
    Feb 2009
    6028
    Re: cincinatti 750 with siemens acramatic 2100
    Why are you posting in the Fanuc forum?
    Oct 2012
    85
    I agree with under the tire but I will say this, the 2100 uses your cutter comp on those cycles if I remeber right and if you input the data wrong it will affect the size of the holes. What was the size of your cutter? I the tool page there are two diameter fields. Take a look. at this it shows that if you put the diameter in both spots it doubles the cutter diameter which in turn would offset it by the diameter instead of the radius. Link to Arrow 2100 manual http://www.cnc.info.pl/files/a2100_iso_204.pdf
    Attachment 275284
    Apr 2015
    8
    Because we are running Siemens Fanuc software
    Aug 2011
    2517
    no one here gives a flying f#%k about that controller ;-)
    you'd be better posting here....
    http://www.cnczone.com/forums/cincinnati-cnc/
    Oct 2012
    85
    Anyway did what I post help you out at all? I have 4 machines with this in my area and another guy has a bunch of the older 950 and 850 in his area but we mostly poke holes with them.
    Apr 2015
    8
    Quote Originally Posted by shags72 View Post
    We got a couple of hours yesterday afternoon to look at this and I am pleased to say that what you suggested worked fine - thank you very much.
    Paul
    Oct 2012
    85
    Glad it helped!
  1. Siemens Acramatic 2100 Display issue
    By msudawg1177 in forum Cincinnati CNC
    Last Post: 12-06-2014, 03:49 PM
  2. Acramatic 2100 Siemens - Windows Virus
    By Chivo in forum Cincinnati CNC
    Last Post: 10-23-2014, 03:50 PM
  3. 2100 acramatic cincinatti contoller 1996 vmc
    By Stephen D Mapes in forum Benchtop Machines
    Last Post: 06-23-2014, 12:39 AM
  4. Cincinnati Arrow 2000 Siemens Acramatic 2100
    By skeetskurt in forum Cincinnati CNC
    Last Post: 02-24-2013, 04:07 AM
  5. siemens acramatic 2100 control
    By jptalon in forum SIEMENS -> GENERAL
    Last Post: 09-19-2012, 12:00 PM
