586,070 active members*
3,409 visitors online*
    Mar 2015
    Program Protected???
    Hello,
    I've got a Doosan VMC 4050 with a Fanuc 21i-MB, I've loaded old programs. But when I go to load a new program it's telling me that it is code (075 Protect) has anyone ever seen this and gotten around it?
    I need the fix quick.
    John
    Nov 2007
    361
    Re: Program Protected???
    What is the program number you are trying to use ?? There are some program number set aside by fanuc for factory use like test programs and warm up programs . I think it is like 8000-9000 you can not use .
    Aug 2011
    2517
    Fanuc's Alarm Description: An attempt was made to register a program whose number was protected.
    as stated above it's likely in the range 8000-9999
    to fix it just change the program number of the program you are loading in.
  1. Protected Move Help
    By WOTDesigns in forum Haas Mills
    Last Post: 12-23-2014, 12:52 PM
  2. Replies: 3
    Last Post: 08-22-2014, 08:13 AM
  3. write protected dwg
    By smudger in forum Autodesk
    Last Post: 09-05-2007, 08:26 PM
  4. write protected
    By stevieboy in forum Autodesk
    Last Post: 06-03-2004, 09:03 AM
