586,551 active members*
3,381 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Question about mach 3's steps calibration
    Jan 2014
    60
    Ok so I have read countless threads about calibrating each axis, the only thing I have not seen is how you do your slaved axis. Can anyone answer how they calibrated the slave axis, or are they always supposed to be the same steps as the master?
    Justin
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Re: Question about mach 3's steps calibration
    They MUST be the same as the master.
    Jan 2014
    60
    Thanks Gerry, probably going to do this tonight and measure with a tape over the length of travel.
  1. Mach 3 Axis calibration (Benchtop Pro)
    By Semus in forum Avid CNC
    Last Post: 02-05-2015, 12:34 AM
  2. KFlop/Kmotion CNC calibration of steps per inch
    By RichChant in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-24-2014, 06:51 PM
  3. Steps per unit calibration problems
    By idtkid in forum Mach Software (ArtSoft software)
    Last Post: 05-12-2009, 04:48 AM
  4. Steps Per Unit” in “Axis Calibration Problem
    By Mr.Chips in forum Mach Mill
    Last Post: 09-03-2008, 02:45 AM
  5. Mach 2 Axis calibration
    By mikie in forum Mach Software (ArtSoft software)
    Last Post: 08-17-2005, 01:19 PM
