603,893 active members*
3,935 visitors online*
    Jan 2007
    25
    Limit switch wiring
    I am trying to wire up my limit switches for my machine and was needing some help. I am wanting to wire them to a db-9 connector to plug in to my controller box. Here is my
    proposed diagram for the wiring. Please tell me if I am on the right track or way off. Thanks
    Attachment 277062
    Feb 2007
    4550
    Re: Limit switch wiring
    Dont forget the Z home switch otherwise its all good.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2007
    25
    Quote Originally Posted by jalessi View Post
    Do I need a Z home switch if I have a touch plate?
    Feb 2007
    4550
    Rstrease,
    The Z home switch sets your Z machine coordinate. The Touch Plate (Zero Tool) sets the work coordinate.
    Jeff...
  1. Does limit switch wiring have to be shielded
    By ozydel in forum Benchtop Machines
    Last Post: 01-02-2015, 06:22 AM
  2. New Limit Switch Wiring Slide
    By EKFER in forum CNC Machine Related Electronics
    Last Post: 09-20-2014, 02:41 AM
  3. Limit Switch Wiring
    By The Speaker Guy in forum CNC Machine Related Electronics
    Last Post: 01-07-2007, 11:11 AM
  4. Limit & Home Switch Wiring?
    By Willyb in forum Gecko Drives
    Last Post: 10-17-2005, 10:02 PM
  5. Home limit switch wiring.
    By DAB_Design in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2004, 12:48 PM
