603,371 active members*
4,529 visitors online*
    Jul 2005
    450
    Mitutoyo digital indicator interfacing
    I recently picked up a 0.001mm accuracy mitutoyo dial indicator from ebay, but it is one of the earlier models that doesnt include min/max readings. Code # is 543-180, and its labelled as IDC-112ME.
    It has a six pin socket on the top, which i assume is a digital output for connecting an external display. Does anyone know what the pinout to this is? or how its used? Any ideas where i can get plugs to fit the socket used?
    Ideally i would like to put together a pic to display the range of readings, so i can measure runout with it, or hook it to my pc.
    Jul 2005
    442
    See attached PDF
    Aaron
    Attached Files Attached Files
    Jul 2005
    450
    Thanks for the info, this is for the model after mine with the 8 pin interface, and mine has a small 6 pin connector, but i think i will try and scrounge a newer dial.
    I checked the pins on mine with a scope, and coulnt find a signal on any of the pins, or even a pin with ground continuity, so maybe the socket is not connected internally.
    Jul 2005
    442
    The signals are open collector, so without a pullup you won't see anything
    Did you check for continuity with the battery negative? I don't think the electronics are grounded to the frame of the instrument.
    Aaron
    Jul 2005
    450
    ah, i assumed there would be an internal pullup. I was doing all my tests with a scope probe by hand, as i dont have a plug for the socket, and i dont know where to find one. Its a 6 pin round socket, with 2 rows of 3 pins.
    I have just taken the back off to have a look, and the socket is connected, but i dont really want to dismantle it any further, and the electronics are under the mechanism.
    When i get into work on monday i will do some more tests with pullups attached, and recheck the pins for a gnd signal. Initially i tested against the casing, and found no continuity on any pins, i will do the tests again wrt the battery terminals.
    Thanks for the tips
