586,269 active members*
3,604 visitors online*
    May 2015
    Unhappy Circular pattern
    I'm Trying modeling this part in Solid works but I've a bit problems about Internal jogs!
    I just could Create this! my big problem is i cant circular pattern that jogs!
    can anybody help me?
    (I'm using solid work 2012)
    Mar 2008
    683
    Re: Circular pattern
    Model one 'ray' of the part and rotate it around your axis.
    When you use the circular pattern try checking the "body" to copy option rather than the "features." And turn off "merge" parts and see if it will copy multiple bodies instead. You can use the bodies for boolean operations. Good luck
  1. Circular bolt pattern wizard question
    By SwampDonkey in forum Mach Wizards, Macros, & Addons
    Last Post: 09-01-2013, 06:14 PM
  2. circular pattern
    By timothy svec in forum Rhino 3D
    Last Post: 05-09-2010, 04:23 AM
  3. Is there a Circular Hole Pattern function in Dolphin?
    By millnturn in forum Dolphin CAD/CAM
    Last Post: 01-21-2010, 04:21 AM
  4. Circular Cut
    By Sanghera in forum Uncategorised CAM Discussion
    Last Post: 11-13-2006, 05:26 PM
