588,169 active members*
4,097 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need some 4 jaw opinions
Page 1 of 2 12
Results 1 to 20 of 38
    Jul 2004
    442
    I'm working on a sharft that I turned between centers. All the critical places on the shaft dead on size, as close as I can measure, (.0001").
    I now need to chuck this piece in a 4 jaw as close to perfect as I can get it.
    Within a few minutes I can get to .001" TIR, and in another few I can get to about .0005" TIR, but no matter how long I fiddle, I don't seem to be able to get it better than that. I have a large collection of dial indicators so I've tried several but they all give the same result. The result is the same turning the chuck by hand or power.
    My equipment is cheap, (Shoptask and stock 4jaw). At first I thought there might be that much play in the spindle bearings, but after each adjustment the results remain constant,i.e. if the high spot is at #3 jaw it stays there until I try again.
    So my question is; can I get it better or is this the best I should expect? I can't imagine there are any tricks to centering, but are there?
    Thanks for all ideas,
    Jerry
    Jul 2005
    12177
    .0005 TIR means the part is .00025 off-center. This is pretty close for a small inexpensive machine. I think you are as close to perfect as you can get it.
    Oct 2005
    251
    Your machine probably will not allow you get any closer than .0005. The part can be out of round which would cause the same problem. You will have trouble on any lathe in the tenth world. Most lathes are not designed to work at that level. .0005 reading on the indicator means you are .0005 TIR and .0005 off center not .00025.
    Jul 2004
    442
    Well I don't agree with that. If you move the piece .00025 in the right direction you'll get 0 TIR.
    Anyway thanks for the advise from both of you.
    Yesterday I thought I'd try one more time to get closer. The high side was at Jaw #4 and I gave it one more twist. Crunch! 30 lbs of scrap chuck; it doesn't look like it's repairable.
    The work piece is a spindle for a grinder, about 9" long with diameters from .625" to 1-1/16". I put the small end in a 5C collet, the other in the tailstock center and tightened the collet, and pulled the center away; .001" TIR at the collet and about .002 at the hanging end. I then put the hanging end in my steady rest and got virtually no movement on the dial Gage.
    I've drilled it that way and today I'll bore and taper it. I'll be interested in seeing how it eventually runs. It will be fine for dressable wheels but I also intend to run diamond wheels and it's those I'm worried about.
    If it's not right, I'll try again, it's only a hobby.
    Thanks again,
    Jerry
    Jul 2004
    442
    Add:
    In Chadwicks book on the Quorn grinder he says a spindle should be bored running in it's bearings. This would be a setup as I've described with one end in a 4 jaw and the other in its bearings and housing, mounted in a steady rest.
    If I must remake the spindle I'll do it that way. more trouble but sounds deadly accurate.
    Jerry
    Sep 2006
    6463
    Hi Ozzie, I've never came across anyone who can measure to .ooo1", and that's in 40 years of hacking metal.
    I once had a bet on with a group of gauge room inspectors and none of them could get the same reading on a work piece due to individual feel for mic's or tolerance on in-house calibration.
    As I recall the Quorn has the wheel spindle running in angular contact bearings, and that is where the accuracy of running lies.
    When you mount the wheel you dress it true each time anyway, even if they are individually mounted on their own holders.
    Incidently, when you get to within .001" of concentricity working with a 4 jaw, it does not pay to crush the work to get it to move, just "tap" the opposite jaw with a copper hammer and it will move, trust me, btdt.
    I currently use a 150mm diam Chinese made 3 jaw chuck, which is 10 years old, and it runs to within .02mm.
    Reason is I don't force it to hold work to the "crunch stage".
    I rely on it to run true and for rough work or bar stock I use an old 3 jaw or put up the 4 jaw.
    Ian.
    Jul 2004
    442
    Yes I was foolish to try to over tighten and as for the measuring, let me be happy thinking I can measure that well, at least I get the result I'm after.
    Surprisingly in the 1990 reprint of the Quorn book, Prof Chaddock, doesn't talk much about the bearings; no talk of angular contact, or ABEC numbers. His quill uses only two bearings, the back bearing against a set of springs that would load them both. The same is true in an inexpensive book I picked up about building spindles.
    There has been a rather thorough treatise here, in this group, on building a quill for milling purposes.
    I'm using all I've read in all sources to cobble a quill for a machine much heavier than the Quorn, to be used by me for both tool sharpening and a little surface grinding.
    The quill incorporates double angular bearings on the front end and a single bearing at the pulley end. I hope it works well, but as I said, it's only a hobby.
    Jerry
    P.S.
    This might interest some oldtimers. My Dad taught me to use a micrometer a little over 50 years ago and the touch is very important. I spent a lot of time back then measuring standards to get the right feel, just 'cause I wanted to learn. At the time he was grinding dies to +/-0.00002" ; needless to say he wasn't measuring with a mic. He was doing the work in PA and sending the dies out of state. He was getting rejections though he thought his work was right on. His company sent him to sort out the problem. Turned out when he cleaned samples with carbon tetrachloride, they measured within the specs.; the preservative oil was the culprit.
    Oct 2005
    251
    .00025 off center is correct. Brain Fart.
    Sep 2006
    6463
    Hi Ozzie, I'm currently, when I get a round tuit, remaking the quill for a Beradi vertical jig borer, which is almost the same as a mill/drill, but heavier proportions and more precision.
    The design which I am using is as you suggest for your spindle, with two angular contact bearings at the business end, and one sealed radial bearing at the top end.
    I'm only using one sealed bearing at the top end, to offset lube problems, and as the pulley drive has it's own double bering set-up with the splined shaft of the quill spindle going through it, there should be no side pull.
    If you are going to use the spindle for a grinding operation whereby the spindle is driven from the end, then I would use two radial sealed bearings to offset the pull of the belt, which otherwise will pull the shaft and render the accuracy of the double front bearing set-up void.
    On the subject of the Quorn, I assumed that angular contacts were used as they are designed for this type of requirement as opposed to radial bearings which are "pressed" into service. (didn't check in Mod Eng)
    I know you can get away with this method, but who would save a few pennies this way when building a Quorn.
    By the way, "just a hobby" is the most important thing a person would want to do for yourself, as opposed to "must do" for an employer, and so you tend to put your heart and a bit of your soul into it.
    Ian.
    Jul 2004
    442
    Hmmm. I hadn't thought about the side pull on the pulley end being enough to warp the spindle during operation. The pulley will be mounted about an inch away from the bearing on a 5/8" shaft, and since I've already bored the housing, changing the plan now would mean a new housing. I'll try this way, bearing in mind what you've suggested if there is a problem when it's done.
    Thanks for the help,
    Jerry
    Dec 2005
    3319
    A new term to learn: repetitive runout which is not to be confused with non-repetitive runout.
    You need to consider that there are tolerances in the bearing: inner ring raceway runout, outer ring raceway runout, inner ring roundness, outer ring roundness plus comparable roundness tolerance in each and every ball.
    Add to this any mounting deficienecies such as housing or shaft runouts or out of round and you can really end up with some bizarre "off" conditions that will affect how the shaft shaft rotates or "orbit" when it turns
    Due to the interaction of ALL these normal and customary bearing tolerances, although the shafts "rotate" just fine, the axis actually moves around in an "orbit" that is extablished by the ever changing "instantaneous axis" that is established by the raceway and balls and the tolerances contained thereing.
    Depending on the ball count, the ball pitch diameter, whether the balls are constantly loaded or they unload and can skid, the orbit pattern will inevitably and eventually "repeat". The problem is the the axis is orbiting all over the place until the stuff realigns at the start position and the path can be traced over. Depending on the ball pitch diameter, ball count, tolearnces, and raceway diameters, this "orbit" will essentially repeat in 15 to 22 revolutions of the shaft.
    THis is often referred to as non-repetitive runout because you don't know nor can you predict the orbit pattern of the axis.
    Thus, the "runout" which is created by the normal and customary orbiting produced by the tolearances noted above is essentially unavoidable and unsolveable unless very special care is taken in the construction of the spindle and, more importantly the component selection thereof. THis is why spindles are ID ground in a fully assembled condition - to reduce/minimize the effect of cumulitive runout at the tool holding interface.
    Now, if you add a belt load to the mix and any runout that a belt load variation may induce, your situation gets even MORE tenuous.
    Now, if you make what is essentially a "perfect bearing" (ABEC 9 runouts, grade 3 balls, precision preload, hand selected and matched in all ways), you can create a bearing that will repetitively runout. Each and every rev, the axis will orbit in the same, relatively predictable orbit path. Yes, there still will/may be an orbit BUT it will tend to be much less or at least manageable.
    Such a bearing would be very helpful in a precision, tool room lathe and/or a spindle for a HDD (Think about it: every time you put a piece of data on a HDD, you want to go back to that point and find the data bit - non-repetitive runout would kill you, REPETITIVE RUNOUT can be lived with/tolerated - think about it for a while, it makes sense).
    When you work in tenths to try to hold runout, anything less than an ABEC 9 bearing with Class 3 balls in a preloaded bearing will result in an inability to "re-find" the prior axis of rotation if the part is taken out of and reinstalled into the spindle.
    Your chances of finding the EXACT same axis of rotation that the part was initially cut on will usually be somewheres between slim and none (reinsert belt load comment here).
    BTW: Handlewanker's comments about repetitively measuring to a tenth is true. We learned the same lesson sorting piston pins. NO two people could repeated remeasure the same pin to the same diametral reading using standardized tool room gages in an environmentally controlled room.
    The chances of even an expert machinist with a god knows what grade spindle measuring runout to a tenth with general shop micrometers/dial indicators in a regular shop environment would involve more luck than anything else....
    Sep 2006
    6463
    Hi NC, I take my hat off to you man, you must have really been round the traps to accumulate such a vast wealth of technical knowledge.
    It's good to be able to pose a problem and get a lot of viable answers from people who've been there and actually done that.
    As much as I dislike bronze bearings and all the problems with adjustments etc, yeah I know there are tons of highly precision machines that rely on the "steady effect" that a bronze bearing gives as opposed to the rattling good fit of the average ball and roller bearing, I still love a good ball or roller bearing set up.
    When I was apprenticed in the late 50's we had a Churchill crankshaft grinder which did the crankshafts for the D8 Caterpiller engines, and to supplement it the company bought another German grinder in.
    The spindle bearing ran in a hydraulically adjusted bronze bearing, and after a couple of seize ups due to the bearing overheating, it was found out (by reading the instruction manual in German) that the lube mix was 50:50 sae 30 engine oil and diesel fuel mix. After that, no problems.
    As far as Ozzie's problem goes I don't think he would have to worry too much, at first, it is only when the radial type bearing slackens up a bit from the belt pull that the shaft could get a miniscule bit of a wobble, which would be better carried on two bearings.
    On one high speed milling spindle design, in the FAG catalogue from some years back, the upper bearing is an angular contact with spring loading to keep it tight, so I suppose a similar design could be applied to Ozzie's single radial bearing to offset the belt pull.
    I don't like the idea of putting any end loading on radial bearings as it just accelarates the wear, unless the loading is fairly light and under a constant spring preload.
    Some of the Taiwanese drills that came out in the 80's had plain radial bearings in the quills and they soon gave trouble under load.
    Ian.
    Jul 2004
    442
    Neat, cool and all superlatives.
    But I'm only a hobbiest!
    Jerry
    Ps. What is the size of these orbits on say a 20X 47 Bearing?
    Dec 2005
    3319
    The eccentricity of the orbit is a complex function of ALL the tolerances as outlined in my prior post. Sometimes the tolerances ADD to each other and sometimes they subtract from each other - depends how they line up during the number of revolutions it takes for the orbit pattern to start to repeat.
    For example via the use of a 7206 bearing, the raceway runout of the OUTER raceway alone (ABEC 1 bearing) is 10 microns ( 1 micron = 0.001mm). The runout potential of the outer ring is 20 microns.
    Thus, you can see an eccentricity of 10 microns in one direction or a stack in the opposite direction of 30 microns. THis is a TOTAL orbit potential of 40 microns if you consider the TOTAL orbit path of movement at the extreme travel limits.
    Add to that the goofy runout potential of a class 125 ball (sphericity of 0.000125" - 125's are commonly used in ABEC1 bearings) and you have PLENTY of eccentricity potential.
    Sorry for the mixed units but that's how they're measured in the industry - I won't deprive you of the joy of converting them to the units of preferred choice.
    ALthough the ball grade for a bearing is typically not published, the ABEC runout tolerances ARE published for the various ABEC grades and thus they are readily available.
    If folks took the interest and investigated what the bearing runout potential for any bearing size was (the specs vary according to bore size) there would be a lot less of a "surprise" when runout occurs.
    Essentially, the things are doing the best that they can with the components that they got in them.
    BTW, if this is only a "hobby", why does 0.0001" runout create a concern????
    Jul 2004
    442
    Maybe it shouldn't. I've had zero experience with machine grinding and grinders so I don't know what to expect from a given setup. I'd like to use diamond grinding wheels on this machine and my guess is that I should make the machine the best I can given whatever abilities and tools I have. When a book says that the piece should run dead on when I bore it, I'm thinking I can get closer than .0005" TIR and that's what started this whole thread.
    How concentric is a $100 diamond wheel with its bore? I have no idea. And if it's off a thou or two does that matter?
    What I'd like the machine to do is:
    Sharpen any mill up to 3/4", all edges
    Sharpen any drill up to 1"
    Sharpen/ make reamers, straight and tapered.
    Sharpen slitting saws
    Grind simple dies after hardening
    Grind all manner of lathe tools, HSS, Carbide and all between
    Do some surface grinding, i.e.tapered gib plates
    So, please tell me, how accurate should my work be?
    The spindle is only one consideration. The work holder must hold the mills very accurately. Precision there may be more important than the spindle. And on and on.
    So I'm building it the best way I know and we'll see what I get. In the mean time I appreciate all help and advise.
    Jerry
    Jul 2004
    442
    Follow-up:
    I'm also building this grinder with an eye toward CNC-ing part of it. If I did the work holder (rotary), and the axis parallel to it, I might be able to grind the spirals on mill sides with CNC.
    If I did one more axis I could grind form tools with proper clearance, Gear cutters, router bits, etc.
    I'd need to accomplish zero backlash, but that's not so hard considering the small loads involved.
    Jerry
    Dec 2005
    3319
    I'm confused.
    Didn't this start out as something mounted in a 4 jaw chuck that you could not get less than 0.0005" runout out of???
    BUT now it seems that the mounting of a grinding wheel somehow got interjected into???
    THe issue of the runout in the lathe chuck pretty much has been explained.
    Runout in a grinding spindle is a TOTALLY different issue/thread.
    Why?
    Because the speed of a high speed grinding wheel induces much more severe loads due to eccentric mounted wheel imbalance than what you would probably be sensitive to in something mounted in a lathe chuck for turning.
    Now, if you're trying to use a tool post grinder to grind something "round" that is chucked in a lathe chuck, you may never get it to spark out due to the non-repetitive runout issue already discussed. If you do, it will probably be undersize.
    How accurate should your work be??? That depends on how good you want your finishes and part tolerances to be as opposed to what tolerances are you trying to meet/hold.
    We hold cam profiles to within tenths of degree to degree profile deviation.
    Diametral size depends on the application (+/-.002 on some apps versus +/-0.005 on others or 0.0005 on others yet).
    Needle bearing journals are held to 0.0005" TOTAL diametral tolerance. Journal bearing journals are held to 0.001" or less, depending on the customer call outs.
    However, from the info provided, I would not be able tell you. "... how accurate should my work be?..."
    This much I can say, however, the more accurate you are able to hold your work tolerances via the use of well maintained equipment, the EASIER it is to make stuff to print no matter what the tolerances called out.
    Precision takes a bit longer to achieve. But in our business, it takes less time to make it precisely the first and ONLY time than if you do it sloppily and in a haphazard method and then to have to make it over (and over) the next time(s).
    Sep 2006
    6463
    Welcome to the world of conundrum. I reckon if you bought a second hand top of it's class cutter grinder, then most of your work would rely on how skillfully you applied the gritty bit to the metal.
    Once you regrind a cutter you are in grave doubt as to whether the cutter was held true whilst regrinding, or if the collet is running out in the mill spindle, or if the bearings were going in ever decreasing circles.
    At the end of the day it is a matter of strive for perfection and accept your best.
    Look at it this way, if the spindle of your tool grinder ended up running out .001" what would be the consequence?
    When it is in the cutter grinder mode with ally oxide grits then you'll dress them before using them, no problem, but you are more concerned with diamond cup wheels, as this is the most likely type you'll use as opposed to edge cutting wheels, sometimes use in the surface grinder for grinding ends of carbide tooling, but not all that often used in the cutter grinder.
    Here the problem would lie in how accurate you can get the faces of the spindle flange and cup wheel to lie.
    Taking the Quorn design as an example, you are relying on getting a PERFECT fit in the taper in the end of the spindle to allow the premounted stones to run true. This is not a problem for ally oxide wheels, but diamond wheels will probably give you some sleepless nights if they refuse to run DEAD true.
    You could always grind the faces of the mounts insitu.
    I anticipate you saying that perfection must be built in at all stages to allow for imperfection as it arises, otherwise it just compounds.
    To sum up, unless you are going to harden the working parts then you will get dubious results from general wear and tear affecting mating fits.
    I have never seen a home produced piece of machinery going the whole hog and hardening and grinding the various parts. It just costs too much to send out to get it done by jobbing shop methods.
    So where does the bearing specifications weigh in this set-up? They would be the least of your problems, even the lowest quality general purpose type would give you superb service, with undetectable runout and smoothness of running, and give years of service.
    Ian.
    Jul 2004
    442
    Thank you all for your help. We've run astray of my 4 jaw question but I appreciate your inputs
    Thanks Jerry
    Dec 2005
    3319
    There have been a number of instances where I've responded to a seeming request for a "how to" and, in reply, outlined a textbook technically PROPER way to do things.
    These included bearing fits for a machine tool spindle, runout tolerances for same, bearing specs for preloading and other points of order. In reply, I often got, "but this is only DIY...." or "...this is not rocket science" or "....you're making it too technical...."
    As 'Wanker points out, there are technically proper ways to do things. If one wants optimum results, one SHOULD and MUST follow the proper methods. Otherwise, less than optimum results can/should be expected.
    Now, when a person is crafting up stuff for DIY/home use, the eternal conflict arrises between what it may cost to do it technically proper versus what the person is willing to spend to acieve "acceptable" results.
    In short, it is easy to lust over/after the sexy actress that you have the hots for and will never ever meet, let alone get involved with BUT we ultimately settle/end up with the girl next door who's generally a lot better person to live and be with...
    That's sort of what one has to do with DIY machine shop practices. Namely try to learn the basics on how to properly do this, that or the other thing (tool grinding, wheel dressing, etc). Then, try to perform the task in the best way possible (you never do at first, after all, the process IS and art that needs to have the technique perfected).
    ONce you can and do learn how to do things RIGHT, you can then use the learned skills to take ever so small steps toward achieving acceptable perfection in your work. You don't get perfect, but you'd be surprised how close you get to it after time if you care to try to improve.
    Have fun in your endeavors...
Page 1 of 2 12
