586,075 active members*
4,018 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco ball screw nut
    Jul 2003
    71
    Where can I find the special tool to remove and torque the y axis ball screw support bearing nut on my 1990 BMC 20? Anyone know what the proper torque for that would be?
    Jul 2003
    71
    bump....anyone?
    Oct 2008
    2100
    Re: Hurco ball screw nut
    Quote Originally Posted by JWC View Post
    Did you ever get an answer?
    I made my own socket to get the nut off, but I do not know what the torque setting should be. I think very low, since the preload is taken up by clamping the bearings in with the collar. The nut is just there to keep the screw from slopping around, and the lock washer keeps the nut from backing off.
    I'm going to try short handle ratchet just a hair more than hand tight (snug) and see what happens.
    Bob La Londe
    http://www.YumaBassMan.com
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  3. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
