603,810 active members*
3,035 visitors online*
Results 1 to 15 of 15
    Jun 2015
    7
    VF3 366 unused alarm
    Does anybody have any insight into alarm 366 unused alarm?
    Machine is a VF3, software version 9.05n.
    I am trying a new program, when running in dry run I get the alarm in a milling block. I have searched the manual and the net to no avail.
    This is the only program I am getting it in. So, I am sure there is an issue with the program. But I have been staring at it for too long and am missing something simple I am sure.
    N4T4 M6
    G17G80G40
    G54
    S1000M3
    G90G0X3.5Y0M8
    G43Z.125H4
    G41Z.05D4
    G1Z-.32F5.
    Y-.5
    X11.5
    G3X11.5Y.5R.5
    G1X3.5
    G3X3.5Y-.5R.5 (This is where the cursor is when I get the alarm)
    G1Z.05
    G0X3.5Y0.
    The program repeats from here pecking deeper.
    What have I done wrong?
    Feb 2010
    1184
    Re: VF3 366 unused alarm
    Quote Originally Posted by Dak109 View Post
    N4T4 M6
    G17G80G40
    G54
    S1000M3
    G90G0X3.5Y0M8
    G43Z.125H4
    G41Z.05D4
    G1Z-.32F5.
    Y-.5
    X11.5
    G3X11.5Y.5R.5
    G1X3.5
    G3x3.5Y-.5R.5. (This is where the cursor is when I get the alarm)
    G1Z.05
    G0X3.5Y0.
    366 (M) MISSING I, K, OR L IN G70, G71, G72 - Check canned cycles for missing values I, K or L
    I also noticed that in the line you have noted, your X command is in lower case.
    Hope this helps.
    Jun 2015
    7
    THe lower case x is an iPad typo.
    I also forgot to mention that when I use a zero value in tool offset diameter the program runs all the way through. If I put a value in I get the alarm.
    Apr 2005
    713
    In that line, you have a decimal place before AND after the R value.
    Jun 2015
    7
    Just checked the program, anothe fat finger iPad typo.
    Jun 2015
    7
    fixed original post typo's
    Feb 2010
    1184
    Sounds like a cutter comp/math issue. It will probably run if you take out the G41 also.
    Hopefully others better at programming will offer better assistance soon.
    Jun 2015
    6
    have had this happen over the years, simply just went the g3g90 i j k route its just a few more characters, and always worked.
    Jun 2015
    7
    I have tried the IJK route. Get an alarm to the effect of invalid IJK. I have to rotate the shape around a part so I am trying to not add any more trig than I have to. When I tried G68 it was worse.
    Jun 2015
    119
    I can't say for sure why you are getting that alarm, but I think the fact that you don't have a lead in for your G41 move might be causing you problems. Sometimes programs will work with compensation not coded correctly, as long as there is no actual compensation value. Try making a XY move into cutter compensation. I ran your program through my control and it worked fine, but my control is newer.
    ____________________________
    My blog: http://www.fletch1.com
    Mar 2010
    1852
    Near as I can see the problem is in the line you are getting an error in. Because your previous lines moves X to X3.5, how can it it move to the same location again and move the Y distance. If you are trying to move in a full circle, X3.5 full circle to X3.5, you can't do it with an R or radius move with a Haas control. An "R" move must be 180 Deg or less.
    G1X3.5
    Of course we don't know why you are invoking cutter comp in the first place or what diameter you are calling up.
    Mike
    Jun 2015
    7
    Fltch,
    Your reply got me to thinking about the G41 and G40 in my program. I think I may have it figured out. I turned on cutter comp at the beginning of this tool. I didn't turn it off until the too, was finished running after doing 20 pecks at 4 different locations, I am cutting T-slots in a 1.25 inch plate. When I changed the program to turn on and off at each location the alarm went away.
    We will see if it carries through for the rest of the program.
    Thanks for the help. And making me think through all of the possibilities.
    Jun 2015
    119
    He's making a 180 degree cut, from Y0.5 to Y-0.5 with a .5 radius. That part should be valid. He makes a similar move a couple lines before, though, so I can't say for certain why that one is bombing out. I still suspect how he is invoking cutter comp.
    A greater than 180 but less than 360 radius cut can be made using a negative R value. From the manual: "The R -value defines the distance from the starting point to the center of the circle. Use a positive R -value for radii of 180° or less, and a negative R -value for radii more than 180°." I'd recommend using IJK for that, myself, but R can be used.
    Mar 2010
    1852
    Quote Originally Posted by Fletch_CNC View Post
    That's what I wanted to confirm---Thanks
    Jun 2015
    119
    Fltch,
    Hey, you're sure welcome! I may not know much, but I try to be helpful when I can be. Cutter comp can be funny that way. When there is no value in the offset, you'll get away with a bit of iffy code, and then when you put a value in and the control has to think it gets all huffy about it! Lol, computers, they do make life easier, right?
  1. Picked up a unused(used) 3040T
    By tauntdesigns in forum Chinese Machines
    Last Post: 08-26-2014, 01:47 AM
  2. Replies: 4
    Last Post: 12-10-2013, 04:36 PM
  3. FS New Unused BobCad-Cam V24 w/Training Videos
    By pepperwood in forum BobCad-Cam
    Last Post: 12-01-2011, 06:02 AM
  4. what to do with unused pins on 16f84??
    By patriciooholegu in forum PIC Programing / Design
    Last Post: 11-25-2009, 02:17 PM
  5. New unused DC Servo Controller...
    By Dave's_Not_Here in forum Servo Motors / Drives
    Last Post: 06-07-2005, 09:32 PM
