586,058 active members*
3,349 visitors online*
    Jun 2015
    SODICK A320 D MARK EX EDW
    Hi! Hope you can help me with this:
    Today when I turned on the machine everything worked in the normal way, but when the axis are moved I see that the values doesn't update in the screen at the moment and they have five minutes delay. The same happening when I want to change the FEED to MDI.
    Another delay is produced when I try to save a draw.
    If someone has experimented this problem I'd thank the suggestions. Here in Argentina I don't have solution from the technician support.
    Best regards!
    Dec 2008
    9
    Re: SODICK A320 D MARK EX EDW
    is the problem solved already ? sorry i was late to read it.
    Mar 2016
    8
    please can you help me,
    i have a problem on my sodick A320D ex21,
    when it is loading it stops on (system loading 12/100) and show red message:
    (SYS2 version up install
    Insert the floppy disk in the USER side ,press the any kay.)
    can you help me pls?
    I Need Floppy disk System 1 and 2 and3
    Outziouar:
    No hablo Ingles si es posible me podrias escribir en Español?
    Saludos
  1. SODICK WIRE EDM MARK 21
    By BKCOM in forum EDM Discussion General Topics
    Last Post: 02-20-2021, 09:03 AM
  2. Sodick A3C-R with MARK IV controll
    By djezowski in forum EDM Discussion General Topics
    Last Post: 01-20-2013, 07:50 PM
  3. Sodick Mark XI EDW AWT Error
    By CDM_EDM in forum EDM Discussion General Topics
    Last Post: 04-05-2012, 04:22 AM
  4. Sodick Mark X1B EDM Machine
    By rajappa in forum DNC Problems and Solutions
    Last Post: 10-23-2007, 03:56 PM
