586,655 active members*
4,599 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Featurecam keeps turning cutter comp off. How do I prevent this?
Results 1 to 7 of 7
    Dec 2009
    100
    I haven't yet found a way to turn Rough and Finish cutter comp ON permanently. For some reason, FC keeps turning it off. I have Enable Cutter Comp ON in Post Options (that stays on), and also it is selected in Machining Attributes, but FC constantly turns it off in Machining Attributes. I use ESPRIT, Gibbscam, and Surfcam and have never encountered this idiotic scenario with those CAM systems. I always use cutter comp for all operations other than 3d surfacing. Can anyone explain what I need to do to turn cutter comp on and leave on in FC for all milling operations?
    Thanks.
    [edit]: 2014 x64 Version 20.2.0.28
    Jun 2015
    Re: Featurecam keeps turning cutter comp off. How do I prevent this?
    There are several ways to adjust these settings in FeatureCAM. As you probably know, you can turn on cutter comp at the feature level controlling a single feature at a time. You can then turn on cutter comp at a file level, which is what you are showing in the pictures you posted, or you can turn on cutter comp at the base level, making it a default setting to have cutter comp on. It sounds like the last option I mention is what you are trying to do. For this you want to go to the "Machining Configuration" page. From within here you will modify whatever configuration is used for new documents (by default this is usually "My Configuration" but could vary depending on settings you have made).
    Jul 2010
    369
    Tolyatti
    Sometimes FeatureCAM is "Dumb"
    Try changing your settings then click save settings now; close the program then open, and see if the settings took..see attached.
    I have had to do this countless time to make FC "remember" its settings.
    Good Luck~!:cheers:
    Dec 2009
    100
    Thanks, and sorry for the very late reply. That IS the way I ended up doing it.
    Dec 2009
    100
    Sorry for the late reply, haven't logged on here in quite a while. I ended up with success by doing it the way Delcamna explained.
    Dec 2009
    100
    Duplicate post.
    Dec 2009
    100
    Thanks VERY MUCH, and sorry for the late reply. I made the changes per Delcamna's post and SAVED them as per your post.
  1. System Comp On Turning
    By fidia in forum BobCad-Cam
    Last Post: 09-28-2014, 08:54 PM
  2. Tool Comp question with VM20/Featurecam
    By kmpstr in forum HURCO
    Last Post: 04-14-2011, 02:24 AM
  3. ?Turning on Cutter Comp?
    By VWbmx in forum G-Code Programing
    Last Post: 02-17-2009, 07:07 PM
  4. Cutter comp on an id hole< cutter diam.??
    By PaintItBlue in forum Haas Mills
    Last Post: 05-06-2008, 12:30 AM
  5. FeatureCam cutter comp
    By Jim Bass in forum FeatureCAM CAD/CAM
    Last Post: 03-28-2006, 02:49 PM
