587,661 active members*
3,346 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > System Comp On Turning
    Jun 2007
    394
    I am just practicing with the V4 lathe.
    I am struggling with the System Compensation when making a groove.
    There are 2 options
    1. Off
    2. On With Collision Detection
    I have drafted up my toolholders and they can be seen in the simulation.
    If you notice in the attached image it is not cutting all the way to the bottom on the groove with the comp on.
    When the comp is off it does not compensate for the thickness of the cutter?
    Really need some help on this as changing the settings for toolpath and tool does not seem to make any difference!
    Pic 1 and 2 are with comp on. Pic 3 has the comp off.
    There used to be a comp with collision detection off. This option seems to be gone.
    Attached Thumbnails Attached Thumbnails turning_problem.jpg   turning_problem_2.jpg   turning_problem_comp_off.jpg
    Jun 2007
    394
    Re: System Comp On Turning
    OK. So I did a bit more looking into this problem
    See the images attached:
    1. Parting tool holder assigned (toolpath is incorrect)
    2. No tool holder assigned (toolpath is correct)
    Any ideas where the error is?
    I am going to play around with the tool holder sketch as it must be causing the problem somehow
    Jun 2008
    1838
    1) Don`t use the System Comp for grooving
    2) Can`t tell for sure but I think the parting tool should be drawn with the XY on a corner not in the middle
  1. Postprocessor for GSK928TD turning CNC system
    By kamcad in forum Post Processor Files
    Last Post: 12-05-2018, 08:42 AM
  2. GSK980TD CNC TURNING SYSTEM
    By canwong in forum Sharp CNC
    Last Post: 02-15-2012, 10:06 AM
  3. Sturges turning system for mills
    By cyclestart in forum Benchtop Machines
    Last Post: 02-09-2012, 03:15 AM
  4. ?Turning on Cutter Comp?
    By VWbmx in forum G-Code Programing
    Last Post: 02-17-2009, 07:07 PM
  5. A System For Milling And Turning
    By kathepati in forum FeatureCAM CAD/CAM
    Last Post: 03-21-2005, 04:46 AM
