588,683 active members*
6,382 visitors online*
    Feb 2008
    216
    External Single Step Button Function?
    Hi Tom,
    Is there a way to add the function of single step command (found on the G code screen) to an external button.c file? It's useful to be able to step through the first bit of a new program one line at a time and if i could do while working closer to the machine with out having to always make sure my mouse is clicking the right button on the screen that would be a nice feature to have as an external button on the desk or pendant.
    Dan
    Feb 2006
    7063
    Re: External Single Step Button Function?
    I do exactly that using my pendant through a custom PCComm function. But, that has to be done within the application - Unless there's some trick I don't know, it can't be done entirely by the KFlop, since it requires calling the interpreter to run a single line of the G-code file, and the G-code file and the interpreter exist only on the PC, not the KFlop.
    Regards,
    Ray L.
    Feb 2008
    216
    Hi Ray,
    Which application are you referring to? We are using KmotionCNC.
    Feb 2006
    7063
    Quote Originally Posted by slimneill View Post
    Hi Ray,
    It would have to be integrated into KMotionCNC by modifying the course code.
    Regards,
    Ray L.
    May 2006
    4060
    Hi Dan,
    KMotionCNC contains a mechanism for KFLOP to communicate special codes to request it to do certain things including Single Step. The supported codes and operations are listed in the PC-DSP.h header file. See:
    KFLOPtoPCCmdExamples.c
    Specifically the call to:
    DoPC(PC_COMM_SINGLE_STEP);
    HTH
    Regards
    TK
    http://dynomotion.com
  1. Add external button
    By ltran2000 in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-09-2013, 12:41 AM
  2. External Cycle Start button
    By Jerry Shorter in forum LinuxCNC (formerly EMC2)
    Last Post: 06-07-2010, 07:59 PM
  3. Interfacing 3 Position Rotary Switch with Cycle Jog Step Function
    By MRM RCModels in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2010, 01:34 PM
  4. Button function
    By ChattaMan in forum Okuma
    Last Post: 11-14-2009, 12:55 PM
  5. Single Step/Half Step Question
    By Hawkeye in forum DIY CNC Router Table Machines
    Last Post: 11-20-2003, 05:28 PM
