586,116 active members*
3,366 visitors online*
    Apr 2012
    25
    Desperate for ideas-z axis only goes -
    I have a bridgeport series 1 cnc running on gecko 203v drivers (3 axis) ...pmdx-134 and pmdx 126 on windows 8 using the mach 3 (32 bit os) runs off of a ess smoothstepper. z axis only moves in the - direction, drivers check out...new bob , new motherboard. reinstalled mach3 wiring correct on motor. cannot for the life of me find why it is doing this........i change y and z......same problem(obviously on y) any ideas.....anyone.....please help-CAM4GE
    May 2012
    231
    Re: Desperate for ideas-z axis only goes -
    have you checked your setting in" port and pins "
  1. Problem with VSD-E in DualDC drive mode, axis 1 works but not axis 2.. any ideas?
    By bmquist in forum CNC Machine Related Electronics
    Last Post: 08-31-2014, 04:08 PM
  2. X axis not constant: Any ideas?
    By becikeja in forum DIY CNC Router Table Machines
    Last Post: 05-23-2011, 03:35 AM
  3. 4th Axis, need ideas
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 07-04-2006, 02:55 PM
  4. Desperate times call for desperate measures
    By lilricky2 in forum Mastercam
    Last Post: 06-14-2006, 02:48 PM
  5. need ideas on Y axis design
    By toolbox82 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-25-2006, 02:40 AM
