586,089 active members*
3,867 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0i-MD - Faceted with AICC 2
    Jun 2015
    18
    Hi, I made this piece machining, and how they see this faceted. The program is made with a CAM. I tried raising and lowering the tolerance, increase and reduce the amount of points. But keeps coming faceted.
    I am with AICC 2 activated with G05.1 Q1 command (or P1, I can not remember at the moment) and working with a velicidad 1200mm / min.
    The truth will never use this control and not to configurations should be modified, but in other controls have not had this problem.
    I know I can solve programming with G02 and G03 ... but I need to solve a point to point program. When you generate a complex surface in 3D it is going to have to be if or point to point.
    thank you very much
    Aug 2011
    2517
    Re: Fanuc 0i-MD - Faceted with AICC 2
    its probably a limitation of the servos or servo controller, PMC or cnc hardware. if you hacked in the extra functions by changing options likely you need to contact Fanuc and get them to add in the required hardware and other settings too. before you do that remove the hacked options ;-)
  1. toolpath is too faceted.
    By declanhalpin in forum MadCAM
    Last Post: 04-18-2013, 03:30 AM
  2. contoured path is faceted?
    By fjbart70 in forum Bridgeport / Hardinge Mills
    Last Post: 06-26-2011, 03:55 PM
  3. FACETED ELLIPSE
    By cncstephen in forum Mastercam
    Last Post: 06-15-2011, 10:23 AM
  4. Fanuc 21i-mb AICC settings
    By contour in forum Fanuc
    Last Post: 01-21-2009, 08:58 AM
  5. Aicc/hpcc Vs Hsm (non Fanuc)
    By highspeedmike in forum Hard / High Speed Machining
    Last Post: 08-24-2007, 01:49 AM
